Kingster Posted July 11, 2020 Posted July 11, 2020 Following the recent visit to a rather wet Cadwell where I was lucky enough to use some borrowed wheels and suitable wet weather tyres, I feel the need for a set of my own. I’d prefer 13” x 7” et 23 (ish) or 13” x 6” et 10 (ish) so that I can make it a nice easy swap at the track and use inexpensive tyres. What you got? Happy to pick up within a 50 mile or so radius of Newcastle.
Andrew Posted July 12, 2020 Posted July 12, 2020 You could probably go down to 6" rims if you're looking at 185 road tyres? I have a pair of 185s on 7" rims that don't sit as nicely as the pair on 6" rims. They worked OK at Cadwell though. If you're planning on using the used race wets that are available, then they're better suited to the wider rims.
AdamR Posted July 12, 2020 Posted July 12, 2020 6s would work well with a set of A021s in 185/70, too, and give you more choice of offsets. Tyres are same diameter as your 205/60s, pretty much, and narrower so they heat up faster. Cheap too if you go for non road legal ones! https://www.tmrsupplies.co.uk/products/yokohama-170-590r13-185-70r13-a021-n2971/
Kingster Posted July 12, 2020 Author Posted July 12, 2020 1 hour ago, AdamR said: non road legal ones! Yup track only! Thanks for the advice @AdamR and @Andrew - great to have your experienced views on this 1
AdamR Posted July 12, 2020 Posted July 12, 2020 7s would work fine as well if you went for the Yokos BTW, opens up options
Kingster Posted July 12, 2020 Author Posted July 12, 2020 30 minutes ago, AdamR said: 7s would work fine as well if you went for the Yokos BTW, opens up options Now he tells me 1
Steve (sdh2903) Posted July 13, 2020 Posted July 13, 2020 Don't know if these are any use chris. Might be a bit narrow on the 5.5" https://www.lotus7.club/forum/market-place/sale-revolution-wheels-x-4-13x-5-12-6-£100
Kingster Posted July 13, 2020 Author Posted July 13, 2020 Might be a bit too narrow - I’ll “do the math” - thanks for the heads up though
AdamR Posted July 14, 2020 Posted July 14, 2020 Those would work great with 175 or 185 "actual" road tyres, I have 5.5" on mine.
Kingster Posted July 14, 2020 Author Posted July 14, 2020 11 minutes ago, AdamR said: Those would work great with 175 or 185 "actual" road tyres, I have 5.5" on mine. You see - just when I thought they were not suitable the voice of reasoning appears
BenD Posted July 15, 2020 Posted July 15, 2020 https://www.ebay.co.uk/itm/13-OEM-FORD-alloys-4x108-courier-FIESTA-ESCORT-capri-SIERRA-turbo-RS-xr-rally/233630123326?hash=item366570c53e:g:kTkAAOSwS8he9QV4 @Chris King - Webmaster and Joint North East AO any good mate
Kingster Posted July 15, 2020 Author Posted July 15, 2020 Offset not ideal but these might work https://www.ebay.co.uk/itm/142534752163
Rich Vaughan Posted July 17, 2020 Posted July 17, 2020 Hi Chris, I have these for sale on here in the For Sale Forum: Anygood? Rich
Kingster Posted July 17, 2020 Author Posted July 17, 2020 Hi Rich I had spotted those - not quite what I’m after though thanks.
