Simon Waterfall Syman84 Posted June 5, 2020 Posted June 5, 2020 OK so as I will probably doing a few more track days now this year than sprinting and I don't want to burn out a set of soft slicks. So where are people getting there used tyres from in need of 180/550/R13 240/570/R13 Or equivalent, something that will last a good few days @Andrew where are yours from Quote
John Loudon - Sponsorship Liaison Posted June 5, 2020 Posted June 5, 2020 Those are odd sizes. Usually cars run 195/530/13 and 250/570/13 in Avons of which if you put a wanted ad on UHR you will get some bites. Those sizes are good on 8-8.5 and 10-10.5 inch rims Quote
Simon Waterfall Syman84 Posted June 5, 2020 Author Posted June 5, 2020 16 minutes ago, John said: Those are odd sizes. They are the size on my wets. So will be slightly higher for clearance in the wet I think. So the size you state above would work. Thanks John Quote
Andrew Posted June 5, 2020 Posted June 5, 2020 I've been using Pirelli 200/540 or Hankook 180/550 on 8" rims. (Both the same tread width believe it or not!) You could probably do with something narrower on the front I guess. I used to use Michelin 16/54 on 6 or 7" rims on the front but the supply dried up, so switched to the wider fronts. You still see the odd 16/53 Michy on ebay but I suspect they'll be getting on a bit. Have got some Hankooks coming from this seller now. Pal (JeffC) negotiated a bulk buy as he was after a set too.. I forget what they cost but they'll be cheaper than on ebay. Worth giving him a call. https://www.ebay.co.uk/sch/paultwin82/m.html?item=274332261396&hash=item3fdf7a1c14%3Ag%3ATnIAAOSwWoRej5MM&rt=nc&_trksid=p2047675.l2562 1 Quote
John Loudon - Sponsorship Liaison Posted June 5, 2020 Posted June 5, 2020 42 minutes ago, syman84 said: They are the size on my wets. So will be slightly higher for clearance in the wet I think. So the size you state above would work. Thanks John No point in copying anything that came with the car. They could be any old ****e just to sell it and not the best 2 Quote
Simon Waterfall Syman84 Posted June 5, 2020 Author Posted June 5, 2020 ok so 8 inch front wheels and 9 inch rear wheels. suggestions please on whats out there that fit those sizes thanks Quote
Andrew Posted June 5, 2020 Posted June 5, 2020 11 minutes ago, syman84 said: ok so 8 inch front wheels and 9 inch rear wheels. suggestions please on whats out there that fit those sizes thanks for the 8" as I posted.. 9" no idea. The 8" slicks I use come from MSA F4 or maybe F3 fronts. They'll use wider tyres on the rear but I think they may be 10" rears ...having just googled .. Btw if you opt for Hankooks C92 is the better compound. Quote
Simon Waterfall Syman84 Posted June 5, 2020 Author Posted June 5, 2020 Just now, Andrew said: for the 8" as I posted.. 9" no idea. The 8" slicks I use come from MSA F4 or maybe F3 fronts. They'll use wider tyres on the rear but I think they may be 10" rears ...having just googled .. Btw if you opt for Hankooks C92 is the better compound. i was wondering about the c92 and if it would be too soft but if thats what youare using then i might give them a whirl Quote
Andrew Posted June 5, 2020 Posted June 5, 2020 6 minutes ago, syman84 said: i was wondering about the c92 and if it would be too soft but if thats what youare using then i might give them a whirl It is the softer of the two.. but the tyres are past their best when we get them. I've used C72 before and they weren't as good. 1 Quote
Simon Waterfall Syman84 Posted June 5, 2020 Author Posted June 5, 2020 https://www.ebay.co.uk/itm/2-x-180-550-13-hankook-soft-rally-tyres-racing-tyres-trackday-tyres-circuit-tyre/283633886111?hash=item4209e5a39f:g:ECYAAOSwfwRdmFm- Tyre Size Pattern Rim Width (inch) Optimum Width (Inch) Diameter (mm) Section Width (mm) Tread Width Revs per Mile Compound 180/550R13 F200 8.0-9.0 8.5 550 238 200 957 C92 looks like they will fit a 9 inch rear as well so just spoken to him he has a few in so think i will get a set 1 Quote
Simon Waterfall Syman84 Posted June 5, 2020 Author Posted June 5, 2020 3 minutes ago, Andrew said: It is the softer of the two.. but the tyres are past their best when we get them. I've used C72 before and they weren't as good. just spoken to him so i think i will give them a go 1 Quote
Alex Gaskin Posted June 5, 2020 Posted June 5, 2020 Try contacting a lower level Formula team. When I was working with Scorpio Motorsport there was a lorry full of old tyres that had only done 2/3 events, lots of life left on them. Since they have no need for them they were willing to sell them for cheap Quote
John Loudon - Sponsorship Liaison Posted June 6, 2020 Posted June 6, 2020 Dint know you had 9s on rear Have a gander at this http://www.avonmotorsport.com/motorsport/radial/13-radial-slick for sizing ideas Quote
Richard Houlgate Posted June 6, 2020 Posted June 6, 2020 When we had the Radical I managed to get some ex F3 slicks from somewhere, I think it was the tyre place in Perry Barr that gave me the lead (BMTR). Not keen to go back to slicks again, what a load of hassle! And no good on puddles. Quote
Simon Waterfall Syman84 Posted June 6, 2020 Author Posted June 6, 2020 3 hours ago, John said: Dint know you had 9s on rear Have a gander at this http://www.avonmotorsport.com/motorsport/radial/13-radial-slick for sizing ideas I have 10 inch rear 8 inch front, on the force set of wheels currently with Avon slicks for sprinting. I have a set of cxr's with a 9 inch rear 8 inch front that I can use for a set of track day slicks. Quote
