Steve (sdh2903) Posted November 15, 2019 Posted November 15, 2019 Piece of plastic honeycomb. Enough to do a westy grille. £sold Pair of braided brake hoses, black coating, came from furore. Fitted on a car but never used in anger. All m10 x1.0. Please check pics to see if they are suitable. £sold Sytec pre pump filter 12mm tails. New never used. £sold posted. 2.0 EcoBoost standard thermostat. Free to any home. 2 x westfield exhaust bobbins. Sold 75mm throttle body. Believe it's one for a mustang. No Tps fitted. Has the mounts on it for a ford IACV or you'll need a blank plate. Also an 80mm silicon elbow to suit. SOLD Westfield cable clutch pedal 5pk belt. £free before they go in the bin. Just cover the post. All proceeds will enable me to buy a new pair of garage shoes as mine are worn out as you can see 1
Wowblaauw Posted November 15, 2019 Posted November 15, 2019 Interested in the throttle body body, will pm in a mo. Thanks, Craig
Quinten Posted November 15, 2019 Posted November 15, 2019 I'd like the honeycomb, but would like to know the dimension so I can ensure it will fit my nose cone...
Steve (sdh2903) Posted November 15, 2019 Author Posted November 15, 2019 7 minutes ago, Quinten said: I'd like the honeycomb, but would like to know the dimension so I can ensure it will fit my nose cone... No probs I'll stick some dims up tomorrow but if you have a standard westfield nose theres enough.
Quinten Posted November 15, 2019 Posted November 15, 2019 Yeah, it's the older Kit nose cone. If you say there is enough, then no bother, I'll take it. PM incoming
Steve (sdh2903) Posted November 15, 2019 Author Posted November 15, 2019 Also still have a set of free build/mock-up shocks available
Steve (sdh2903) Posted November 16, 2019 Author Posted November 16, 2019 Throttle body and silicon bend sold.
wizzer Posted November 16, 2019 Posted November 16, 2019 I'll take the exhaust bobbins please. Pm me please Tony
Steve (sdh2903) Posted November 16, 2019 Author Posted November 16, 2019 Exhaust bobbins honeycomb grille build shocks all gone
LoneWolf Posted November 17, 2019 Posted November 17, 2019 I'll take the braided hoses if they fit the M16 calipers and widetrack wishbones. And the Sytec pre pump filter as well please. Thanks
Steve (sdh2903) Posted November 17, 2019 Author Posted November 17, 2019 @LoneWolf sorry no idea if theyll fit the m16 calipers. They are long enough for widetrack depending on where the caliper port is located. Let me know if you find out if they are suitable
LoneWolf Posted November 17, 2019 Posted November 17, 2019 13 minutes ago, Steve (sdh2903) said: @LoneWolf sorry no idea if theyll fit the m16 calipers. They are long enough for widetrack depending on where the caliper port is located. Let me know if you find out if they are suitable I'll take them anyway, looks like they should fit. I'll message you later today for address and payment
Steve (sdh2903) Posted November 17, 2019 Author Posted November 17, 2019 Brake hoses and filter gone.
Steve (sdh2903) Posted November 18, 2019 Author Posted November 18, 2019 @Quinten @wizzer @Wowblaauw @LoneWolf all bits have been posted today. Should be with you In a few days. 1 2
