Dave Eastwood (Gadgetman) Posted August 25, 2019 Posted August 25, 2019 For clarity, this is a Westfield FW style rear, which is what the seller seems to have, (given the arches etc) (Note the pictures are random, Googled photos, not the posters car!) And this is a ZK. Note, it’s only the rear bodywork style that affects the Anti roll bar fitment, either style lower body can either have a matching nose and bonnet, or the opposite type, (ie FW rear, ZK nose/bonnet, or ZK rear, FW nose bonnet), this doesn’t affect the rear ARB, only the lower body, or tub does.
AndyD-Yellow Peril Posted August 25, 2019 Posted August 25, 2019 32 minutes ago, Steve Davis said: Will take some pics of the screen tomorrow and try and add to the advert. Yes it is a black frame, but heated function not tested. I can buzz it out and put some power to it. Will take a close look for chips etc. Was removed as I fitted an aeroscreen. I am right on the Herts,Cambs, Beds border. If @mikey p decides not to take the windscreen, can I have second dibs @Steve Davis Thanks Andy
Steve Davis Posted August 26, 2019 Author Posted August 26, 2019 More pictures of things for sale. Windscreen examined, no chips or cracks. Heated element has 3.5k ohm resistance and draws 4a at 12volts so assuming that works. Have also found..... Windscreen wiper assembly. £50 Doors. £150 the pair Wet weather cover. £150 Front ARB. £50
Steve Davis Posted August 26, 2019 Author Posted August 26, 2019 10 hours ago, mikey p said: Hello, I'm interested in the windscreen. I guess it has black frame and uprights? Any chips or scratches? Pictures? Wiring all I'm place? Where in Herts are you? Thanks Mike, Have posted more pictures including screen. Tested element, seems ok. Thanks
Steve Davis Posted August 26, 2019 Author Posted August 26, 2019 10 hours ago, aeg said: Hi, any pictures of the carpet and trim please, cheers Andy Andy, See new pics of carpet etc. Just needs a good hoover, daren't do that at 6:30am! Steve
Steve Davis Posted August 26, 2019 Author Posted August 26, 2019 For clarification, here is a picture of my car. Before the diet!!
Dave Eastwood (Gadgetman) Posted August 26, 2019 Posted August 26, 2019 OK, so it’s not an FW rear anti roll bar! Have you a picture of the back of your car to confirm (for the rear wheel arches/wing protectors) You have an adjustable in-board style front anti roll bar, which can be used with all Westfield body shapes and wide or narrow track front ends. You then have an adjustable rear anti roll bar, suitable for ZK rear bodywork Hope that helps!
Steve Davis Posted August 26, 2019 Author Posted August 26, 2019 Dave, My car is definately a FW body with an earlier chassis/rear end. This is according to Andy Silman. Thanks for your help!
Ricky444 Posted August 26, 2019 Posted August 26, 2019 Hi will the rear arches fit a 2003 megabusa if so I will take them cheers Richard
Kingster Posted August 26, 2019 Posted August 26, 2019 59 minutes ago, Ricky444 said: Hi will the rear arches fit a 2003 megabusa if so I will take them cheers Richard Only if it is FW body style as discussed above.
Steve Davis Posted August 31, 2019 Author Posted August 31, 2019 Windscreen sold. Carpet sold. Rear anti roll bar sold. Thanks lads.
