Cadwell Park 23rd May
35 minutes ago, Oily Steve said:
Thanks @Andrew for organising the discount :yes:
It's easy. You just need five willing bods. :cool:
Yeah is head is moving around a bit did say after the ride with you it was hard work trying to keep his head straight.
Adam and I, yesterday. To be fair he scrubs up alright.
  • Haha 1
What were you sitting on? It looks like your head is poking out above the cage?
A baby seat filled with expanding foam, obviously.
A vid from Stoney in the red zetec.
He's pootling behind me for a while then chasing after Ross's Caterham.
Last one from me .. honest. :)
First part is stalking the Lobster again. Not sure what happened at about two minutes in @AdamR? Forgot to mention it after the session... was I supposed to go past or had you just feathered off the throttle a bit more than you intended? Anyway was a good session.
Second bit.. after letting Stoney and Ross past I tried to hang on. I'd been having trouble with my glasses dropping off my nose for most of the day. At about 9mins 30 in, I'd adjusted my goggles and snatched a gear. Unfortunately I hit 4th instead of 6th! I calculated that would be about 8300rpm if I was fully off the clutch.. vtec Pinto. :suspect:
6?
8 hours ago, Archibald Meatpants said:
6?
You got me there Russ.. 6 geese a laying? ???
6 gears a gearing? What box have you got?
Ah, I thought you knew. Did it not have six when I took you round Donington? It's a Caterham 6 speed. 1:1 sixth gear. Just the job for a tuned Duratec. :yes:
Catering van box? Fits a pinto.
Edit - Ha! Beat me to it!
It's a direct swap for a type nine.
Yes - my reply was more of a statement on the fit 👍
