Steve (sdh2903) Posted March 24, 2019 Posted March 24, 2019 Having a sort out as the garage is a tip. All free if you can put to use before I bin it. Either collect from pa6 or postage at cost. 4 x wheel spacers. Smidge under 20mm thick. Donated to me but needed a different size. GONE clutch pedal for cable clutch 2 x standard fuse boxes GONE 2 x plastic mounting plinth for 95mm lights (not angled) alternator pulley. Came off a 40a denso Pair of brake flexies. Never used. One locknut and 1 sealing washer missing GONE Haynes manuals GONE duratec/EcoBoost thermostats. Cant definitely say what temp they are. I *think* the shorter one is 82 and the bigger 90 but not 100% SHORTER ONE GONE. 2" exhaust clamps x2 GONE 5 rib aux belt
Kingster Posted March 24, 2019 Posted March 24, 2019 Steve I'll be interested in brake flexis if they suit Sierra rears by any chance?
Trevor Little (Trevturtle) - Treasurer Posted March 24, 2019 Posted March 24, 2019 I'll have the fuse boxes please.. Postage to derby.. thanks
CRAIGR Posted March 24, 2019 Posted March 24, 2019 Interested in spacers and brake line if not suitable for Chris
Steve (sdh2903) Posted March 24, 2019 Author Posted March 24, 2019 @Chris King - Webmaster and Joint North East AO I assume they'll be ok for Sierra rears thread wise but may be a bit short on length? Your welcome to them to try and if no good list them back up? @CRAIGR @Wowblaauw PM me your addresses and I'll post them then let you know the cost rather than guessing if that suits?
Kingster Posted March 24, 2019 Posted March 24, 2019 1 minute ago, Steve (sdh2903) said: Your welcome to them to try and if no good list them back up? Sounds good to me - I’ll pass them on to @CRAIGR if they don’t suit. You got my address still?
DamperMan Posted March 24, 2019 Posted March 24, 2019 1 hour ago, Chris King - Webmaster and Joint North East AO said: Steve I'll be interested in brake flexis if they suit Sierra rears by any chance? Sierra rear and indeed cortina fronts are m10x1.0.
Steve (sdh2903) Posted March 24, 2019 Author Posted March 24, 2019 Sure Brad. PM me your address and I'll chuck in the post then let you know how much.
fildyke Posted March 24, 2019 Posted March 24, 2019 Hi Steve. Do you know what the ribbed belt is off? Im after a spare for my silvertop zetec but it's a non standard size. Cheers Phil
Steve (sdh2903) Posted March 25, 2019 Author Posted March 25, 2019 Hi Phil it's not off anything specific. I just ordered it slightly too short for my build. The 838 part of the number is the overall length (or circumference) of the belt in mm.
Steve (sdh2903) Posted March 25, 2019 Author Posted March 25, 2019 Also still have the free set of build shocks here.
fildyke Posted March 25, 2019 Posted March 25, 2019 40 minutes ago, Steve (sdh2903) said: Hi Phil it's not off anything specific. I just ordered it slightly too short for my build. The 838 part of the number is the overall length (or circumference) of the belt in mm. Ok no worries I need a 1000mm one.
