The Mini Diet/Track Car Thread
those seats must weigh a ton each :popcorn:
Front seats will go when I have found some eBay bargain replacements
You only need one. Who needs friends. They just upset corner weighting....:d
  • Haha 1
11 hours ago, KugaWestie said:
Harness bar fitted
Gary are those brackets you've fixed the harness bar to structural? They only look to be spot welded in place? I'd also recommend against having the bolted connection in tension due to the risk of the bolts pulling out in a hard front impact or if shell deforms in a crash. They'd be much better if you could mount them in shear.
Mark, thanks for the observation.
The brackets I have mounted to are the same bracket that held the rear seat belt upper mounting which is why I used them.
What I have made is an copy of a bar that is available on the market to purchase.
I will take a look though and see if there is a way to improve it
And you hardly need that thumping great battery , another cwt saved :)
Are the rear belts up and over though - so bolts would effectively be in shear on oem fitting?
Picked up a pair of these a few days ago for a great price
I have not weighed them yet but they are not that heavy, so should save me a few kilos
Bargain second hand Sparco harnesses arrived today, so they got attacked with the pressure washer at work and are now hung up drying in the garage
Much cleaner
Good to see work progressing on the Mini Pooper :p:laugh:
Harnesses are dry and a lot cleaner
Look almost like new in the photos, now.
Yep, there are a couple of dirty spots on them still, but for £40 all in for both sets I am happy
  • 4 weeks later...
The Mini is all loaded up ready to take to work tomorrow to utilise a nice flat workshop floor.
The main job is sorting the spongy brake pedal out. I am taking it to work so that I can utilise the private land to test the brakes and bed the pads.
If I get time I hope to swap the seats as well
  • Like 4
