Snetterton 300 20th September 2017 - Javelin Trackdays
the stat isnt completly closed as i found out its about 20 percent open so still allows oil around i did a thread on it a while back
Where do you take your temp reading from?
2 hours ago, darve said:
@Dommo @Gary (KugaWestie) - North Oxfordshire AO @lewis @bunje
Were you running an oil cooler?
@Kit Car Electronics is that a good price? (V busy at the moment so little time to research....)
Yes, mocal one mounted in front of the engine... though I'll be changing to a laminova to dump the heat back into the coolant over winter :d
2 minutes ago, bunje said:
a T peice off the oil pressure sensor
There's little flow there so I reckon you're under reading there
Are you over cooling then??
where do you take your oil temp reading from @Dommo
I don't know as I don't run a temp sender. That stems from the days the engine was cheaper than the sender!
Change to laminova is packaging related rather than trying to fix a particular problem. I don't seem to have any over/under cooling issues but couldn't tell for sure. Other than nothing has blown up.
@bunje I have a boss welded to the outer edge of one of the side wings on my sump
@Kit Car Electronics @Kevin (Mr T) - Joint Essex AO
looks like I've just ordered an oil cooler as linked to by Mr Mike...... to be delivered tomorrow hopefully.....
just called up and only 35 of 90(!) spaces booked so no rush to book on
I am running a remote oil cooler now  but was not when just N/A tuned. When N/A tuned I did upgrade to a Radtec though
