Aerorace radiator ducting
Ledge thanks :)
So, how many carbon sets are you making for us fellow S2000 boys then Tom?
13 hours ago, Tom (T3OMF) - Cotswolds AO said:
Yes Russ
Pm me your address, then when I finished with them, I'll post then on
These could be come as widely travelled as Bob's legendary build stands :yes:
Yep, I'm forwarding them on to @matthew902
Not sure how much Royal Mail they'll withstand though!
Jared (Tableleg) has offered to turn the templates into a PDF to share on here which may be easier when everyone's finished with them:t-up:
They are made of the finest cardboard:d
Well now that's a good idea :t-up:
I for one, know Toms got the carbon sheet already................... Although I managed to remove some carbon from his garage today :oops: He's got far too much of the stuff........
Great idea, I should be able to do the same which might speed the availability up :t-up:
All ready  :d ;) :t-up:
Doodle me a set please Tom. I'll exchange it for  very expensive engine breather fitting :laugh:
Hi Tom,
How are you going to do the corners as you appear to have flat sheet CF.
Also, check the clearances on your car. I had to take 20mm off the WF kit as my rad is further forward in my nose.
Tim
Thanks for that Tim, my rad is slightly thicker as well so I wont be making it as long if that makes sense. I won't be trimming the template though :yes:
 I have a plan for the right angle not sure if it's going to work or not yet
All masked up ready for the templates :d
On 11/01/2017 at 19:20, Tom (T3OMF) - Cotswolds AO said:
OK, need help to deride
Carbon on the inside or out side??
