Aerorace radiator ducting
Any condition as I only want to use the pieces as a template, going to try and make one out of Carbon
Flash git :p Must be nice to have a rad with mounting bosses on!  @CraigHew has one fitted. I'm sure he's got time to make a cardboard copy for you!
now than would be ace :yes: :suspect:
Tom,
What's the point of a carbon one?  You might save 50 grammes or so?
If there's nowhere else left to lose weight, why not? If you do I can't help feeling making a one-piece item from a mould will reduce weight even further if possible.
@Tom (T3OMF) - Cotswolds AO I'm happy to pop nosecone off and take whatever measurements you want.
I'd like a cardboard one too, if poss. I am going to make one and affix it to the inside of the nosecone as have no rad fixings either. But in alloy as I dont have a carbon addiction in the same league at Tom :oops:
I have one in the garage that's not been fitted yet, I can take some photos & measurements if you want.
Save Craig taking is nose off!!!
That would be perfect and as you say would save Craig taking his nose off.
Ok it might not be until the weekend.
Thats cool, I'll PM you my address to send it to
Wow, that's absolutely perfect, thanks ever so much
:yes::yes::t-up:
Tom...could I have those templates when you're done?
Yes Russ
Pm me your address, then when I finished with them, I'll post then on
