Sold: 2015 Westfield Mazda SDV
Hi all,
Due to starting new project I have decided to sell the Westfield, I just don't have time to use it anymore and I am going to be losing the use of the in-laws garage from xmas so I putting it up for sale...
Car was built from a P reg MX5 1.8 with 80k on the clock. The components I used from it were...
Engine + box
Diff + driveshafts
Propshaft (modified by bailey morris)
Front + rear uprights
Wiring loom + ecu/fuse boxes (modified to take out extra circuits)
Instrument panel
Steering column + stalks
The car was built with the following spec..
New 2.4 rack with solid mounts
New front+rear wheel bearings
New front + rear calipers pads and discs
New upper/lower ball joints/rack ends etc
Westfield coilers front+rear
Lightweight alloys with Yokohama Parada 2 tyres
Matching spare with same tyre with carrier to fit if needed
Aerodynamix rear diffuser
lightweight racing battery
Engine was stripped + inspected + rebuilt with genuine Mazda gaskets/seals
Shortened sump
Front of cam cover removed for ease of access
New sensors fitted (o2,temp, oil etc)
Westfield 4-1 manifold and westfield carbon repackable exhaust
Spare chrome exhaust with cat for MOT time
Coolant reroute done
BMC CDA carbon air filter
T7 designs heater to demist screen - other outlets can be added to heat the cabin if needed
Westfield padded race seats - drivers side is on runners
Full carpet set
New Prima Motorsport Titon 3" harnesses with rotary release
Full wet weather gear with framework stowed in place under rear boot cover
Bad points - there are a couple of scratches in the gel coat on the o/s side panel and due to the car being in storage whilst we moved house, there is also a mark on the front corner of one of the cycle wings where is has rubbed against something.
One owner (me!) and I have copies of all the documentation relating to registration and IVA as well as lots of build photos. The build was started in 2014 and completed in 2015. MOT not needed until 2018. Car is on an age related plate. Mileage is currently 4038 (speedo was reset when car was built) and although I don't drive it that often it may increase if we get a good day!
Due to the scratches listed above I am putting this up for
Any questions please ask! More pics are in my archive!
Wow that's cheap!
That will soon go at that price.
Good luck with the sale Shaun and as the others have already said thats definitely been priced to sell and IMO would make a perfect first Westfield for somebody.
Hi guys,
Yeah I have priced it for what I need out of it so hopefully it's a bargain for someone...
Pm sent on here and Locost on behalf of friend :)
Sold subject to completion by CraigR's friend!
Excellent :) Thanks Shaun
That was quick.
Less than two hours.
Yes it was quick! I know I could have put it up for more, But thats the amount I needed to get out of it...
How come this was advertised on here I'm sure my mate Rob has arranged with you to pick this up on Friday?
Hi Phil,
I am now selling to another member who contacted me before Rob, Rob is fully aware of the situation.
Thanks,
Shaun
Hello Shaun, was a nice car, someone definitely got a bargain.
Will you need a riveting gun for your new project - if you do I know where one is. :d
Hi Mate,
Thanks for the kind words, You can keep the rivet gun, I got given a similar one a while back, sorry I should have told you at the time!
Thanks,
Shaun
