Zetec 2.0 Silvertop Dunnel Option 3 Engine + Quaife Sequential Gearbox for Sale
Hi all,
Looking to go down a different route with my Westfield 7 SE build so I have a zero miles since build Zetec 2.0 with Dunnel Option 3 kit (Circa 215bhp) as per here http://www.dunnellengines.com/zetec_carb_optionkits_3.php Bottom end was fully checked over when engine was built by local motorsport mechanic. As mentioned, this has not been run since the build so is basically brand new. Also comes with shallow wet sump, Water rail, lightweight motorsport alternator, 45 DCOE’s, Dunnel ECU & Wiring Loom. £4000 o.n.o.
Also a Quaife QBM1M 4 speed sequential gearbox (https://shop.quaife.co.uk/quaife-in-line-4-speed-sequential-with-drop-gears)  includes digital gear indicator, prop shaft, type 9 and Vauxhall bell housings and drop gear ratio kit, hydraulic clutch, again, very little use by previous owner so like new. - £3250. o.n.o.
Also unfitted/unused Geartronics Easyshift ECU flatshifter - £250
Please PM me if interested in both or either, ideally would like to sell together.
Thanks.
