photo 1
photo 2
photo 3
photo 4
photo 5
Weber 45 DCOE, 45mm 20xe Inlet Manifold, TPS and Ramair filter. Everything you see in the first 3 photos. Has 150 jets fitted and also has 165 jets that will come with it. Had them setup by Peter Baldwin on standard engine, Mbe Ignition and Sbd Manifold peaked at over 200 but held 196Bhp on his rollers realistic figure is around 185bhp as his admittedly run high. They will need a re-tune as they have been on and off a few times. £450 Plus Postage
Mbe 967ig Ran with the Carbs still fitted in car but will be removed shortly. Has a complete loom as well. Will need tuning to suit your engine bu has a good base map for a standard engine £250 Plus Postage
SBD Weber 48 DCOE  Inlet Manifold (last 2 Photos) £60 Plus Postage
Have a 52mm inlet and 52mm Jenvey throttle bodies to sell very soon has fuel rail, Cable linkage and trumpets for sale soon, also untested go tec pro x ecu for sale as have had a change of plans.
Happy for Collection
St.ives
Cambridgeshire
