Westfield 1.6 race car *Full rebuild with Honda K20*
Thanks for the kind words chaps.
Really can't wait to here it at full chat with the throttle bodies and straight cut gears.
I got the bell housing from a company called mcgreggor Motorsport in New Zealand and it really is a work of art.
Dan
It's starting to take shape now, latest pics;
26DAE1AF-D614-444F-8C9B-08157D3E1036_zps
0485DABB-41C1-4715-B97B-53B6B86238DF_zps
61603667-B805-4557-A669-88998B57F82A_zps
1B79AF97-504E-4FF7-AB9C-8D82500D32FD_zps
FD5B170A-D6AD-4AB6-A914-175D4C55A5D4_zps
A62D27FA-54FF-4BDE-9030-2CD0E660E9A3_zps
Windscreen has now turned up so I can get that fitted. Need to get some arch protectors, tunnel top and boot cover ordered then it's engine in time.
Dan
Few pics of the windscreen mocked up, carbon half doors and new front arches;
77466165-28BD-4E18-B3E2-727FBD208039_zps
2DB901D0-BBDE-4BB3-A609-56DDD2DC495F_zps
4301B708-5C61-4F74-9F33-B34F0D33A69A_zps
B583E686-AF58-408B-9B36-01ACFA11C3E8_zps
9F8423D7-500E-45FC-9FEE-1FDFEEDA8401_zps
Dan
  • 4 months later...
Overdue update!!!!
As per normal the Westfield has been sat and not getting any attention, que the nice weather and realisation that I need to get this on the road this summer.
So its time for the biggie, engine in...
Obviously the engine mounts etc are all been custom made with the help of a friend who owns 'finneys garage' in Conningsby. I'll let the pictures do the talking....
E686B4CB-04B9-44A9-9B24-000EEA09E8DA_zps
3BF540DA-A068-4097-82FA-F5D3763FC46B_zps
C49B2792-FE1E-4FA2-ACA6-2DE6A7169F81_zps
DDE91C35-429D-4146-B8EB-FFA43EA0E8AC_zps
E563501F-F997-4088-B418-2E17EFA7CBE9_zps
EDDFEDED-CACD-498F-836D-35803B5E4157_zps
8C724544-BDED-436F-B2AF-96FCF61147D9_zps
62A19201-4DCD-45CC-8868-A4B0A7121AF1_zps
E019D2B9-B2F1-460F-BFC7-3940216DFBB9_zps
0D9C04D4-4EF2-4B37-BF06-08015946B432_zps
Engine fits ok-ish... it literally only fits in one place as the dry sump pump is very close to the front wishbone mount. The gearbox is further forward than before thus I will need to make/buy a remote gear linkage, I don't fancy reaching under the dash to change gear! The prop shaft strangely needs shortening, had me confused for a while but I think the diff we are now using has a longer casing.There isn't much room for an exhaust manifold and the alternator is going to be a push and may need a smaller one. (I think someone said this may be the case!)
The floor clearance is going to be fine with the dry sump, and I'm hoping the throttle bodies and filter will fit under the bonnet with no holes no keep induction sound down for track days.
I do however have not much space left and lots still to fit.....Dry sump tank/hoses, oil cooler and hoses, engine ancillaries, exhaust manifold, radiator etc.....needless to say its going to be a tight squeeze and busy engine bay!
We are going to look to see if the engine will need further support to stop it from twisting once they are complete.
Overall its going to be hard work but possible, which I am really happy about!
In other news after much deliberation I have decided and sourced my cams, it was between the drag cartel, TDI north and Skunk2 Drop in cams (all retaining the stock valve train but adding circa 10hp and a slightly nicer aggressive feel to the engine characteristics.
Truth be told it seems that the other two both give slightly more peak hp but are double the price. I'm not chasing peak power as for my driving ability I will hardly be exploiting it to start with anyway! So I'm hoping for a comfortable and exciting 250bhp.
I have also got a friend Aaron (owner of AJ restorations) to shave the Honda of the rocker cover and spray it gloss black, he's done a great job.
Will need a custom exhaust manifold making along with an exhaust (mine is currently 2" and wont be sufficient, does anyone have any recommendations for this?
Many thanks
Dan
Missed this update;
With the extra grunt upfront I thought it wouldn't be a bad idea to improve the stoppers.......but then I thought nope let's save money and get it on the road.
Then Matt got some awesome looking bright red brembo brakes for the mx5 conveniently delivered to me, so I couldn't resist!
I had seen that Westfield had been supplying some hi spec race calipers designed for use with 13" wheels and lightweight cars... So on the look out I was.
The end result some 280mm discs, hi spec r114-4 calipers and fitting kit. Unsure of what pads to go for as of yet.
I got them home, un-packed and test fitted  :shock:
Will these fit!!! It was close, as in wheel weight removing close!
But I have one side on and they rotate with no clearance issues
Pics;
Before...
2ADC4785-EE73-4323-9D1C-59EBC58BFCD4_zps
Fitted...
17731905-1532-48D1-9491-D8D8DF7F7DDF_zps
6FFD8EE4-B8BB-438F-A0EA-E7DAED05FCB4_zps
E4192380-EA46-4977-9EBE-D1A231439208_zps
F45DB9B5-B83B-41A0-B96C-83F95BF59A55_zps
1D1F67E4-DF00-4A08-A8A8-9D95DB05F811_zps
Dan
Hi Dan,
What did you fix the half doors to the car with?
'Magic' I've only offered them up, I think I will be making some brackets for them so I can take them on/off.
I'' update when I fit them properly.
Dan
Dan
I'm looking at doing the same, it will be difficult to get in a caged car with them fitted.
Defiantly in from the top!
Dan
Dan
Yup! Bit of skateboard griptape on the side impact bar ;)
Looking good so far!
