Darve's little upgrade thread
not sure tbh. need to know what to do to diagnose the problem. will speak to blink as they know all things about the mx5 engine :d
just hope it's not an expensive fix :(
I'm hoping it's not a similar problem to what mine had a few years back :oops: but this is the thread I mentioned and it might give you a few things to check out.
http://forum.wscc.co.uk/forum/index.php/topic/82920-engine-smoking-badly-and-getting-worse/?p=828658
Pleae ignore the witterings from our "guest"
just found that on the search - it didn't look like that when I took the head off :-/
will mull this one over. at least the car wont need much use this time of the year :d
Have you got the plastic restrictor in the camcover breather pipe?
Also hVe a look in the back of Rods manual, I think there may be some suggestions there
mine goes to a catch tank with the pcv valve blanked off. absolutely zilch in the catch tank.
Will have a look in the rods manual, thanks
If memory serves me right I think Rick (tigbrother) had a problem with oil loss on his once, which was on his blog. Not in front of my PC today so can't link you to it. Mark will probably have a link for it
and indeed I do :d
http://mx5-westfield.blogspot.co.uk/
When we was following you last night Bob and I could smell burning oil when you accelerate so I think a compression test is first on the list.  Gauge is in me garage if you want it.
will be in touch Bernie :)
here's what's going on (ignore the fast idle, IAC valve mapping needs tweaking) :(
will start a techie thread to document my findings for the benefit of others
bl**** hell that sounds tappety / knocking ?
i know very tappety :down:  :cry:
has that tapping got worse
are they hydraulic tappets if so are they getting enough oil pressure
exhaust colour looked a little white at one point is your head gasket ok.
is the timing still ok or has the belt jumped a cog.[tapping]
That definately sounds a lot worse than when I last heard it ???
