2010 Westfield SEIW Mazda SDV 1800 - Sold pending collection
Built by TIG brother on this forum. I cannot give enough credit. It's a fantastic build and the quality and attention to detail are 2nd to none.
2010 Westfield SEIW based on a Mazda MX5 1800cc
9800 miles
Mot Sep 2014
Tax end Aug 2014
Receipts for about £15k in parts/kit alone.
Registered in 2010 the car has taken an age related plate based on the donor MX5.
Using a brand new Westfield SEIW wide build kit, everthing was new apart from the following:-
Engine
Gear box
Wiring loom
Drive train
Brake calipers.
Full specifcation as follows:-
Engine:
1994 Mazda Eunos 1800cc
Standard bore
15mm shortened sump and oil pick up
New big end shells
New oil seals sump
Full new piston ring set
.09mm total head and block skim to bring back to tolerance
Full de-coke of pistons and combustion chamber
Full new genuine mazda head gasket set
New inlet / exhaust valve stem seals
Reground valves
New spark plugs / leads
Rocker cover gasket
Block painted satin black
New water pump
New cam belt
All related tensioners
Cam shaft seals
Modified 2 1/2 inch polished alloy intake with ITG cone filter
MAF sensor relocated
Carbon canister delete
Transmission:
Standard mazda 1800 manual gearbox
New clutch release bearing
New clutch slave cylinder
2L 75/90 fully synthetic transmission fluid
New prop shaft seal
New gear shaft oil and associated gaskets
Baily Morris shortened prop shaft
Torsen LSD differential
Cooling:
One off alloy fabricated radiator
Full coolant re-route
Silicone hoses with alloy pipe work
After market rad fan switch
5 year advance pink coolant
Standard mazda cooling fan
Braking:
AP racing split master cylinder
Dot 4 fluid
Goodrich braided brake hoses
EBC Green stuff pads
CRN grooved discs (front)
Standard discs (rear)
Mazda calipers and hand brake system
Electrical:
Mazda loom
with the following removed:-
Air con
Power steering
Headlamp motor controls
Electric windows
Speakers
Audio system
Heating controls
Heater motor
Standard mazda ECU
Interior:
Carbon mods dash
Trilogy Savage blue illuminated switches
Revolution gauges:
Speedo
Rev counter with shift lights
Fuel
Temperature
Oil pressure
Momo 290mm steering wheel
Westfield 4 point harnesses
Exterior:
Post office red ZK body work
V8 bonnet
Playskool Full roll bar
Black mesh vents
Carbon mods cycle wings
Carbon Mods rear arch protection
Caterham Carbon fiber font indicator pods with clear lenses
Carbon rear light upgrade inc reverse and fog with full LED lighting Inc reverse and fog
Hella Thinlite high level brake light
Team Dynamics 1.2 pro race 15" wheels in satin black
Toyo T1R 195/50/15
Long range fuel tank
Included in sale:
Remainder of my WSCC membership can be transferred to new owner also.
319D776A-DDE2-44CC-8A7D-D9BBD3085F99_zps
42C7CFF1-A647-4DC3-9A90-1B72DB4C5779_zps
C6B43337-1BF3-40D7-BA9F-D524B41B0E0E_zps
4D652F81-E5A1-42C7-9887-7E3FF0A1BCC6_zps
7B8861D6-60AA-44DC-B698-A77C3B4ADA53_zps
5C457EE8-004F-4E7A-8566-90746C76F35D_zps
1D11A06B-A2B7-4765-B328-9E2D2A37B27B_zps
743CA917-7FC1-4223-B440-9D306C5430A0_zps
137DBE21-4E04-420D-AB35-4276C312B0C5_zps
795E49C7-68BB-4F17-87EA-1DF9D9679A36_zps
Apologies. Forgot everyone was on 56k in this world. Forum software just killed all my IMG links and turned them to hyperlinks.
wow this looks a clean motor….wont be long for sale don't think... :)
4A88A64B-8CF3-4255-A4AA-18FDD5962492_zps
03C4DCE5-2C35-4CC2-8F45-D97DD236355D_zps
6B8B6171-81B2-42F5-9BC3-81CAF9F50AC9_zps
3D56229A-AFBA-4941-A45A-205EE88282A7_zps
16C0A94F-84F8-43E4-BF90-9FF0D04A9AF4_zps
C6C6C18C-B743-4E9E-A5F0-4DB427963152_zps
248E8080-D2D3-400A-BBDA-E6816973CB9D_zps
EA6C521E-42AF-42E6-9B24-0EF3C0133942_zps
F3F6D434-2CA5-4B47-ACEB-36D9DE2AEA0D_zps
F1722EF9-6EFD-485A-BF38-BC9EC1E5A611_zps
34236DE5-0D93-4E86-8343-43FDA20A71FF_zps
E8560CB3-A905-42C7-91D5-A535FAE6213F_zps
does look nice and fair play to you on the price too
good luck with the sale and let us know what you end up with :t-up:
Cheers Cleggy. I'm sure I could stick it on PH or eBay for £11k and see what bites I get. But that would not be fair on Rick whom I purchased the car from. I spent a fair bit on a decent track day camera setup, but it's optional if someone doesn't want it. Not sure why they wouldn't though. :)
Nice. I hope my build turns out that well (mine's the same color combination too). Good luck.
Morning
Quite interested,
My own car has just been written due to flood damage in January / February this year and hence I am on the hunt for something to replace it
Has it had any sort of professional set up done on it? This was something that I always wanted to do with mine but never managed it
I don't want the camera set up, could you please advise on value of that, if you were to remove it
With thanks
Ian
Car would be £9k without it. The builder had tracking and camber gauges. It's not been corner weighted.
It's Stoneleigh next weekend, I can't see anyone with knowledge of the kit scene really wanting to do anything before, now we're so close.
Thought someone may want it to go there with. :)
It's to new to import into Canada, pity, I'd tear your arm off for this one, good value. Good luck with the sale.
Edited to include that this also has the long range fuel tank.
