KugaWestie's Blog
  • entries
    8
  • comments
    47
  • views
    17,307
Electric Mirrors Upgrade - Part 2
KugaWestie
I picked the job up again this afternoon, and decided to fit the switch into the dashboard.
Firstly I chose my position
Then I cut away the vinyl and foam very carefully, followed by drilling a series of holes to form the square hole
After some tidying up with a file, the switch is in
Whilst out collecting some last minute bits today, I picked up a can of top coat paint.
I sanded one of the primed mirrors down with 800 grit wet and dry, and gave it a couple of coats.
More to follow - but thats it for a few days now!
9 Comments
Recommended Comments
deanoecosse
Looking good so far Gary. Are these mirrors a direct replacement for the Metro ones or do you need to do a bit of modifying?
KugaWestie
Thanks Dean
A very slight fettle needed on the pillars, you will see in my next update
Gary Argent
Hi Gary - I'm planning to do this modification on my Westie soon - I've managed to pick up two mirrors on eBay which seem to be in quite good condition.  Can you remember which primer and top coat you used, as I also want to spray mine black?  Thanks.
KugaWestie
Jesus, that’s over 10 years ago! 😂
Hycote rattle cans I think
Gary Argent
Thanks Gary.  Might be 10 years ago but the blog has been very useful to me, planning a similar project!  I've ordered some rattle cans, will let you know how I get on.
Dave Eastwood (Gadgetman)
It’s such a comparatively simple mod in the scheme of things, yet just makes the whole driving experience “better” in a subtle way; you don’t tend to realise till you start using the confusion, how often you end up putting up with badly adjusted mirrors, where you can’t quite see behind you properly, and how much extra stress that can add.
Flying Carrot Steve
Sorry Dave but what do you mean 'start using the confusion'? It's a typo I'm sure but I can't figure out what the correct word should be
Conversion.
as in, start using the conversion,
Flying Carrot Steve
Personally I find my mirrors are great and don't move unless I knock them walking down the side of the car inside the garage. I also have a Longacre rear view mirror which shows me pretty much everything, way better than a standard tin-top set-up does, so I never find myself in the situation of having to adjust them on the move.
