BTW, the green MNR in the vid was ZZR1400 powered I think, and was OK for noise, so it can be done.
Ah memories :)
Mine does not sound as good anymore with the spud gun :(
You don't need any fancy car for Rockingham all you need is -------
<iframe width="420" height="315" src="http://www.youtube.c...bed/AZKZDuxY6l4" frameborder="0" allowfullscreen></iframe>
:p :p :p
I think they got a bit lost there! :laugh: I've never driven that layout. :d
They are Frontera drivers :suspect:
I don't remember seeing static testing there before, might be a new thing or maybe they just spot test if they have any problems on driveby. I'm still up for this date anyhoo.
:yes: OK, I'm still in.. so that's Me, Steve H, & Stoney for starters. Got a few hefty bills to get out the way before I book on though. ;):t-up:
I'm still up for this , got my Acousta fill so hopefully with a repack I should be ok for noise , just got the small issue of fitting my new dry sump , water pump and cooling system !
Only three weeks to Oulton Matt!
Yeah , I know Steve ! , sump on now , just need to order some hoses .
I'm hoping its going to warm up a bit between now and then !
It'll be fine :cool:
Just been looking at Rockinghams T&Cs http://store.rocking...ms.asp#cartrack
All vehicles must comply with the venue noise limit of 105Dba static. ALL vehicles will be noise tested prior to being allowed on track.
Hope that helps some
Steve
that helps a lot :t-up: :t-up: :t-up: :t-up:
but just recall steve mentioned :(
Have confirmed that they will static test for 98db but if it fails you still get a go at the driveby. Why bother with the static one wonders
I'm going to rely on the fact that in the half dozen days I've worked there I've only had to have a word with one guy about noise and his Skyline sounded like a Harrier taking off. I've never seen them do static testing but if their own terms say 105 then it's something that we can point out on the day if necessary.
:t-up:
