DAZ Posted March 16, 2003 Share Posted March 16, 2003 Do you want reverse you can go electric or mechanical £300-900 elec on sierra diff only.Propshafts £200 sump baffle kit £50 probably new radiator all hoses and fan £200 maybe new fuel pump £50 wiring loom will need modifing engine mounting brackets £ the thing with BEC is weight the less you have the better it is,so you may be changing things just to save weight wheels/windscreen exchange for areoscreen will probably have to change diff,i know next to nothing about this but the list will probably go on,you could always try Yahoo groups bike-engined-cars these lads will help you out. DAZ Quote Link to comment Share on other sites More sharing options...
DodgeT Posted March 16, 2003 Share Posted March 16, 2003 to convert x-flow to blade power is not a big job at all. I had martin @ the kit car workshop fit the engine ( cause i havent got a garage, let alone welding facilities aprt fom dinner times at work ) then did the rest with the help of a friend (you know who you are ) to do the conversion, all you need is; engine complete with all ancillaries, loom, ECU, carbs, clocks exhaust manifold (fisher fury type lovley piece of kit see martin) exhaust can off a fireblade bit of pipe to mate these together TTS jets & filter new prop shaft gear linkage kit hoses for water & fuel somebody to make the engine bracketry & above all, plenty of time & patience, Ive got neither ask catflap. martin had the car for 2 weeks, most of that time was weaiting for bits, then its taken 2 weeks to finish off all the other stuff, but theres been fitting new seats & allsorts of stuff dont let people put you off saying itll cost thousands, its cost me less than £1500 by the time I sold the stuff I took out. theres no way spending £1500 could of improved the x-flow to this level of performance/enjoyment ( just IMO of course, i still like the x-flow as well ) Quote Link to comment Share on other sites More sharing options...
