OOOT - VOIP and Netgear WNR2000 Router
Ping 192.168.1.4:
packets sent 4,  received 4, lost 0
Ping 192.168.1.1:
Ping 64.111.80.5:
timed out
  • Replies 76
  • Blatman
    28
  • RichP
    24
  • ACW
    8
  • Lurksalot
    2
So the phone and D/G appear to be OK, and the DNS has been set up to not respond. Nothing wrong there. You have PM...
Ok, has anyone else tried to follow this and thought
EH???   :blush:  :blush:
I struggle to understand how the light switch works, never mind all this malarky!
I may ping the dishwasher later then pong the iron  :)  :)  :)
Even I'm lost now...
Bob, try pinging the microwave instead ;)
Nurse, I need an espresso...
:D
It's got me foxed as well!
Fantastic timing for the return of Blatman though - I'd have filed the lot under "bin" before now otherwise!
If the phone is not registering, i would think the router is forwarding correctly....
the type of VoIP you are using uses Port 5060, forward that port to your phones IP. You did mention that you put the phone in a DMZ, so of course this might not work :0)
Just read back, and your phone's DNS needs to be set to either your router (usual setup), or a DNS address that your ISP uses. I use 208.67.222.222 which is an open free service.
Forgot to ask... can you ping the phones public IP address, assuming it's NAT-ed, what's the translated (ie the public) IP address of the phone? Can you see it? Can you ping it?
Gotta say at this point, VOIP is not realy my strong suit. Security is much more my bag :blush:
Thanks all - will try some of this tonight.
Response from ACN Tech support:
"We are not aware of any specific issues regarding the VP and your particular router model. However, I notice from looking on the net that many people have had issues with VoIP/SIP and the WNR2000.
In particular I have seen one report where a user could not get VoIP working after upgrading the firmware in the router to the lastest version. Have you upgraded yours? Which firmware are you on? He was able to sort his issue after downgrading to version 1.139.
Another user could not get VoIP working at all:
“We eventually got the phone to ring by effectively using alternative SIP ports (5070-5071) instead of the standard (5060-5061) but still no voice would come through (this was with port forwarding as well as with the box in DMZ).
Eventually we gave up, him (customers ISP support) saying it was the WNR2000s SIP ALG that was doing something wrong, and it cannot be disabled in the router interface.”
If this last report is correct then the VP will not work with your router as the VP requires the standard SIP signaling ports, 5060-5066, to be open. Here is the full list of ports used by the VP:
SIP signaling:    5065-5066 TCP/UDP
Video RTP:        5000-5001 UDP
Audio RTP:        9000-9201 UDP
Firmware upgrade: 5514 UDP/TCP
There is one router I know for sure that is not compatible because of a SIP algorithm that is incompatible with the ACN network (Linksys 610N) so it could be that this is the issue you are experiencing with the Netgear WNR2000.
We do have many customers using Netgear routers successfully (putting the VP into a DMZ and disabling the SPI firewall).
Our recommended router is a Linksys 160N."
I'm a bit worried that they say the one router known not to work with the phone is the Linksys 610N, and then they go on to recommend the (similarly coded) Linksys 160N. Dodgy?
Can't recall how to identify the phone's public IP address?
Many thanks again
Rich
Only sped read this...... but
Your router will need to be able to inspect SIP signalling and then dynamically open up the RTP ports for the Voice Media ports (these are dynamic). In addition it will need potentially to change the SIP messages data if the SIP device is on a private inside address and not a real public ip.
An alternative is to put the phone on a real IP, and then usually most devices can have a specific range of ports defined for RTP. You can then set up port forwarding for signaling (UDP/TCP 5060) and the RTP ports (UDP)
I was just going to say that... :devil:
How do blaters - ru well. This would be a lot simpler question if it were Cisco IOS eh ?
Ok - I read the post a bit more, Can you on the netgear define a DMZ with real public ip addressing. Ie set it up so the phone has a real IP address. This will remove NAT from the equation. I suspect the netgears ability to handle Nating of SIP.
Once you have done this you could open all IP for a test. If this works then it will be a case of locking down the RTP ports on the SIP endpoint and setting up the firewall for these.
