Cleggy's Spyder Rebuild 17 07 09
front axle off, engine and gearbox removed
really wanted to start looking at getting the chassis finished off so I can get it sent away for blast and paint -
to make the welding and flooring job easier I made up some pivots - the chassis now spins a treat and will sit at any angle and hold itself without the need for support - basically I got luck with trying to find the centre line  :t-up:
front mount with has a plate so I can drill in whatever position I like to hold it steady enough to work on - this bolts on with the 4 bolts that hold the front beam on
rear one fixes straight on the fork
didnt P**s about making it look pretty but works well
been a long while since I have seen underneath
more gas required for welder and TBH a better welder
Excellent cleggy!
What a great idea :laugh:
Looks like it gonna work well
will come up soon :t-up:
let us know when you are thinking of popping over  :t-up:
better get some stronger tressles , them Machine Mart jobs must be getting close to there max load capacity by now  :p
the next blob of weld could be the straw that broke the camels back  :laugh:
bit more progress made
picked up gas refill gas bottle from BOC - only charged me £32 cause I was waiting the best part of ten minutes before I was served  :suspect:
decided to splash out and buy a gel battery - although this may end up on the westy if I get bored one weekend  :devil:
also picked up some aluminium - used ASC Metals in Peterborough - good service, they let me walk around and select what I wanted and even cut it for free although I had to help that chap with the guillotine (thank the lordy for spell checker) - walked out with two slightly damaged 2m x 1m sheets cut down to fit in the car -  just £40 which I thought was good value
one sheet is .9mm and the other 1.5mm which I shall use for the middle floor sections
had a bit of thin tin laying around - made up a template in cardboard and cut with the sheers and trimmed with tin snips to size
tacked up
welded up - not that tidy but will do
tidied up a bit with me old m8
need to start thinking about a metal folder - might make one? anyone seen any plans to make one up?
my rotisserie'd beetle
it is noisy because the accelerator cable is dragging on the stand
Your just showing off now cleggy, video's ha ;)
Looks like it works well mate
I was wondering when we would get the film version  :laugh:
cant wait for the sequal  :p
I like to do my filming in the nude  ;)
to much info mate, just make sure that there are no mirrors in the garage :laugh:
It's coming on nicely Cleggy.
With the appearance of pre-production footage, I assume you have sold the film rights to "Cleggy's Spyder Rebuild"
Cleggy:-I like to do my filming in the nude  ;)
Oh that explains it!, it must take a lot of practice to keep the camera steady with the right hand while doing something with the left :p
You mean turning the chassis over?
