Cleggy's Spyder Rebuild 17 07 09
midge more done tonight - gave up the hunt to try to beg/borrow a m14 tap - so scuttled off to cromwell tools to let some moths out of that piece of folded leather that lives in the back pocket
ended up getting a right hand tap from them and ordering a left handed one off the ebay tonight along with a couple of rose joints
whipped up some ends on the lathe last week - tonight I put a chamfer on the ends, drilled and tapped
in hindsight  wish I had of left a step on the ends - but hey ho there's always next time
welded, ground and filed up to make em look neat
this piece will get chopped in half ready for the left hand threads - left and right hand threads either end allow you to adjust the length by turning the tube in situ (obvious to most I know  :blush: )
also made a start on mounting the seats up properly
Turning and polishing yer own knob in the garage....
Does it get any better than this?   :laugh:  :laugh:
Top job mate, still enjoying the thread...especially as it now turns both ways.... :laugh:  :laugh:
I'll get me coat.....
well fanks Dave  :t-up:
I will now show my nob to all who enter my garage  :oops:
anyone else finding firefox b****y crashy at the moment  :bangshead:  - I have noticed for the last couple of months it is nowhere near as stable and glitch free as it used to be - might go try try chrome again I think
got the gear shift back on the lathe tonight and took the end down a bit so it fits into the pivoting part - left it long for now
over the last few nights a made up some framework to go under the seat to offer a bit more support - bit like a westy you tend to have to stand on the seat to get in and it was making all sorts of crackin noises with my 15stone
still yet to fibreglass repair the seat -
also finished off these ready for fitting and have started making up the brackets to weld onto the framework - TBH didnt really nead to be rose jointed, I just fancied doing them that way - guess if I add some storage in the back there it may help  :suspect:
on the lookout for some bench mounted metal shears as I am going to make a start on putting some flooring in soon - anybody got a machine that is no longer required and wish to sell?
I got some ply and a jigsaw mate...........
i'll get me coat :D
yeah when you get to your age jigsaws are a nice way to while away the time  :p
nipped the frame off tonight so that I could start cleaning of the glue and other crud off the rear part of the tub - total ball ache of a job, probably 2 hours just to do half a side
anybody got any tips for removing seriously hard dried on glue - tried thinners which didn't help too much, then acetone which was slightly more effective followed by a scraper
had some of the products I sell in Practical classics magazine  :t-up:
Good comeback :laugh:  :laugh:
Acetone generally gets it off but it is hardwork, and if you got that lot off in two hours you did well.
See if anyone else has a better idea cause i have to do this sort of stuff quite a lot at work and it would be nice to find something that really works.
Keep at it mate its looking good. :t-up:
made up the frames that support the seat bases and tonight mounted up the seats to see how everything fits together
and have finished off removing the glue - just two stumps where the hands once were  :0
thinking about getting a bead roller  :suspect:  for the floors
thought I would have a go at make up a flat fibreglass panel tonight - have had 5kg fibreglass kit kicking around that I purchased of ebay some time ago
usual bloke didn't bother reading any instructions other than the mix percentage - so this is how I did it
use a large flat ceramic floor time and laid masking tape across
cut five sheets to slightly over size and then added the catalyst to my measuring jug full of resin - pack recommends between 1-3% mix- being a bloke I went for 2% and in hindsight I should have gone for 1% as I never did get to lay the 5th sheet down
ended up with what looked like a rather large Jordan breast sized gelatinous mass in the bottom of the measuring jug which I enjoyed fishing out  :blush:
splodged a layer of resin on first then started laying the sheets over and using the roller provided in the kit - in hindsight again I noticed when I had finished the job that the sheet was slightly thinner at the edges so perhaps more time working the resin outwards would have helped
used my builders flood light to dry quickly
free product placement for Carlsberg - if Cleggy made Porsche Spyders - you can fill the blanks  :laugh:
really pleased with the results for a first time go
gloves of the disposable type are a must as it is a horrible job and a good face mask helps too - was not long before Julie came and slammed the garage door shut
jigsaw to cut around then job done - always nice when the bits actually hold themselves in
just need to fibreglass them in place inside the tub (where it will be carpeted eventually) and then fill on the outside
need to do the same with the old seatbelt slots, heater channel holes and where the old instruments were fitted on the dash
should I try to get some resin around the edges?
oh and ordered an odyssey extreme 25 battery today - not sure whether to swap with the standard one on the westy though
QUOTE
Can't leave you alone for a minute can we
Resin alone without reinforcment is brittle and will crack and break up with time , mix with talc to make your own (messy job) or buy a tin of fiberglass car repair paste .
to be honest you could save time by filling the other holes with a tin of that ready made fiberglass matting stuff (forget what its called ) but its basicsally chopped strand glass in a paste form .
a peice of flat board suitably placed at the back of the hole why you fill it with the resinglass mix , ( use plastic sheet so it doesnt stick to the job ) then finish off with resin filler paste and sand down till smooth .
job done  :t-up:
Thanks Jay n Bernie
Bernie - I think it was you that suggested making up my own panels some time ago  :t-up:
I will get some of that filler but stick with the plan to fibreglass my repair pieces in and then fill rather than just using filler - should be stronger
just off into the garage to have another few hours messy play
cut the blanking pieces for the dash and the variety of holes that the tub has and have really enjoyed fibre-glassing them in  :angry:  but hey it is one step close I guess
numbered them up and marked top and then super glued them in place to make it easier for when the fibreglass was applied
have also removed all the crud from inside the tub - took forever but looks much nice now - TBH this will all be carpeted but at least there will be something good to stick too now
from this
to this
chased out the cracking in the gel coat with the dremel -  ordered some fibreglass filler yesterday
rather than the horrible vinyl on the dash I will have it sprayed to match the rest of the car - although this could be fun as there is no record of the paint colour - although I was told it was re-sprayed at a Porsche specialist - anyone take a guess?
QUOTE
Yep, for some odd reason my wife doesn't get excited about the whiff of polyester resin.  I tend to stockpile what has to be done and then blitz it if she goes away for the weekend.
Of late I've done a bit of carbon fibre work at home and whilst it's a bit trickier to get a good finish as you have to align the weave, etc, swmbo doesn't seem as bothered by the epoxy resin, which hardly smells at all.
