Im 99% sure i'm going for a minno max, but spanner in the work at the last minute.  BJ said this to me:
Can you check the dimensions of your cars as I have overall dimensions for a Westfield wide at 3660mm long x 1710mm wide, if this is the case with your car it wont fit onto the Minno-Max but would need the A-Max (AM-T-110) with a bed size of 3600mm x 1760mm as a minimum of size bed.
Can anyone confirm what the overall dimensions of my westy are?  Its wide track front suspension with 185 tyres at the front, and 205 tyres at the back.  Cheers!!
  • Replies 31
  • Blatman
    6
  • Asterix
    5
  • Crazy Eddie
    4
  • JeffC
    3
Offset it important too if it's that close...
FWIW, both my wide track equipped cars fit on a standard Minno. The SEiW car has 195x50's on 7" rims, but the offset is something like ET26 (ET37 wheels with 11mm spacers...). Any wider or a thicker spacer and it probably wouldn't fit...
