but usual form is to drop pressures slightly when wet
Is that what you have found works ??? most folks seem to up pressures a bit when raining/wet  ???
yep, always drop the pressures. people raise pressure becuase they can't get the temp in the tyre which raises the pressure but lower pressure means more tyre movement on the limit and therefore easier to judge when limit is being approached - or something like that! :D
So that settles it. I'll try upping the pressures a bit and then maybe I'll try letting them down  :laugh:  :p
All I hope is I get more traction than I did this evening in the wet. 2nd gear was useless and 3rd not much better  :suspect:  :suspect:
Just checked the weather and the chance of rain has dropped from 60% to 20%  :D
See you all tomorrow
  • Replies 246
  • Mark Stanton
    23
  • custardtart
    12
  • Asterix
    11
  • Mikey91
    11
you out to play on friday matt?
if so il have to give you a trailer race on the way up
Sadly no - car has no engine or gearbox -  but I'll be there as a passenger with a fellow member of the "custart tart racing" team!  :D
Will pop over for a chat.  :t-up:
Barney says the drivers briefing is 9.00am, but my circular from the Boss Man says be there for 8.00am. I shall struggle to get there for 8.00, should be there by 8.30 at the latest. Hope that's all right??
9am is the briefing,everyone should be ready to go as the first session will start as soon as....
cheers
barney
heya guys. just a quick question...
whats the noise limit at mallory tomorrow?
and another question ... I live very close is ok to just drop by and spectated fror a bit ?
word of warnign if its raining heavilly at mallory tomorrow watch for standing water in the braking area into the shaw hair pin. it runs across the track and makes it easy to aqua plane or lock up under braking.
Oi, stop being a pessimist, the forecast is improving all the time.
any word on the noise limit guys?
Gordon, last time I was there they didn't test for noise.
So unless you are outrageously noisy you will be ok.
Cheers,
Rich.
105db is the limit although am informed its quite relaxed!
Right setting off now, see you all there in the glorious sunshine that has been booked.
Kevin
ah thats okay then. think i am sittng on about 100 at the moment.
Will be coming to spectate and eat bacon rolls if the weather forecast is as good as it says.
