It's IN!!!!......It's out
Scott,
hope you got my pm,
had a similar problem,
my clutch failed so removed engine put in helix clutch reinstalled.
Clutch slip  :arse:
Turns out the westfield bell housing stops the arm from retracting fully.
Cut out more of the bellhousing behind the arm,
we also modified the arm to give more clearance too.
Works fine now
Quite a common problem I believe  :bangshead:  :bangshead:
Keep going Scott, its worth it
:cool:  :cool:
  • Replies 57
  • scott beeland
    25
  • pete g
    12
  • brianm
    3
  • pistonbroke
    2
Scott I hope you've got it sorted. I Can't believe that its taken a day to put a normally asperated 4 pot in ? XE's are easy peasy should have taken no more than 2-3 hours max... get your finger out boy :p
Buzz
Scott, did you get my message about the short oil filter  ???  ???  ???  ???
It will be all worth it in the end Scott  :cool:  :cool:  :cool:  :cool:  :cool:
Yep. we found a listed champion filter for the astra 2.0 16v that was shorter and went on no problem
Scott,
hope you got my pm,
Clutch slip  :arse:
Works fine now
:cool:  :cool:
All that has already been done mate and was working fine with old clutch set up (ceramettalic paddle)
Buzz
If you wanna come down and chuck it in when I've got a clutch sorted feel free.....As I've got no enthusiasm to go back in the garage. On nights for a week from tomorrow so nowt will get done until next tuesday at least
It'll be worth it in the end Scott....
Keep the faith........ :t-up:  :t-up:  :t-up:
Oh the faith went a loooong time ago mate. We're now at "got to do something as it owes me a fortune" stage
Don't know Pete, Still got water oil mix, got mayo only slightly in water, and mayo, ish in catch tank. Used about a gallon of fairy to shift the residue. f*****n sick of orderin Vauxhall head gaskets.
Plus a rattle at about 4K on hard accel.
Plus a rattle on start up, sounds like tappets, but wasn't there 100 miles ago. Goes when hot but comes back  on cold start.
Comps are still 200+ all round hot or cold.
tomorrow will see the old head back on.
Rapidly losin the will,
Bri.
Not sure if you are aware but early red top heads crack the oil pipes in the head causing the emulsified oil you are talking about in the cooling system. I worked on vauxhalls for about 10 years so i have first hand experience of this happening many times. We used to use a company in Wales that reworked the heads curing the problem for all time, not sure if they are still around though sorry?
HTH
Si
I'm saying nothing about Zetecs here, Scott would probably blow a gasket.
I hope you get it sorted soon mate.
Go crack open an Easter egg, and go back to it tomorrow, it'll all seem much less of a problem when you've slept on it.
Kinneck , ever tried sleeping on a VX   :p
[All that has already been done mate and was working fine with old clutch set up (ceramettalic paddle)
As a thought have you changed the fly wheel ???
No but is has been machined flat (to get rid of a wear step) and then the clutch cover is mounted on washers
Am I right in thinking though that there are two (broadly) types of C20XE clutch cover. One for the early flat type flywheels, that is presumably deeper, and a shallow one for the later pot type flywheels? I know I have an Astra GTE pot type cover which fits my aly flywheel OK, but wouldn't fit the flat type flywheel on my other engine.
Dunno which my flywheel is...How do Itell?
dave
i believe there are two types of cover as you  say.
yet i used the early type cover on my ali flywheel.
there was a slight difference in adjustment had to make a bush to extend clutch cable.
scott early flywheel is flat later pot type has big lugs on it ???
May be, I can't help on that one though; I kept the hydraulic clutch system that I fitted for the steel ultralight flywheel and 7 1/4 clutch that I'd originally planned to use.
