scott beeland Posted April 15, 2006 Posted April 15, 2006 Mucho spannering from me and Gromit today and the XE finally dropped into place.......Then we discovered there was no clutch function so it's all been dragged out again and it's back on the garage floor Supposed uprated helix version of std cover plate. Except when the bolts are tightened on the clutch assy the fingers dissapear inside the cover therefore rendering the clutch non operable. Added to phils van troubles; a mad search for a short oil filter for the xe and a puncture in the Xantia tyre we've had what you might refer to as a sh*t day and I'm giving serious consideration to breaking the car Quote
pistonbroke2 Posted April 15, 2006 Posted April 15, 2006 To Morrows Easter Day Scott All will come good in the end. You dont want an easy life do you or you wouldnt have bought a Westy and you certainly wouldnt work for the N.H. Peter. Quote
scott beeland Posted April 15, 2006 Author Posted April 15, 2006 Like easter day when everything is fuggin shut so I can't sort anything out? Quote
pete g Posted April 15, 2006 Posted April 15, 2006 scott what part number your clutch cover. will check mine to see if same if you want. Quote
scott beeland Posted April 15, 2006 Author Posted April 15, 2006 Can you pm me your part number and I'll see if I can dig mine out. Thanks Quote
brianm Posted April 15, 2006 Posted April 15, 2006 Scott, I hope you are having a slightly less ****e experience of installing your new XE than I am, Cos I cannot figure aproblem that I haven't had. Can we torch them both together?, kind of a group trash thing. Head off again tomorrow, Did I mention A***?? B. Quote
scott beeland Posted April 15, 2006 Author Posted April 15, 2006 Scott, I hope you are having a slightly less ****e experience of installing your new XE than I am, Cos I cannot figure aproblem that I haven't had. Can we torch them both together?, kind of a group trash thing. Head off again tomorrow, Did I mention A***?? B. Mine doesn't feel any less shi* than that at the moment..And torching the whole lot is high on the agenda at present here too. I won't even be venturing into the garage tomorrow Quote
brianm Posted April 15, 2006 Posted April 15, 2006 Don't know Pete, Still got water oil mix, got mayo only slightly in water, and mayo, ish in catch tank. Used about a gallon of fairy to shift the residue. f*****n sick of orderin Vauxhall head gaskets. Plus a rattle at about 4K on hard accel. Plus a rattle on start up, sounds like tappets, but wasn't there 100 miles ago. Goes when hot but comes back on cold start. Comps are still 200+ all round hot or cold. tomorrow will see the old head back on. Rapidly losin the will, Bri. Quote
pete g Posted April 15, 2006 Posted April 15, 2006 what a b******* hope mine goes more smoothly Quote
pistonbroke Posted April 15, 2006 Posted April 15, 2006 Hang on in there scotty , your place is booked for curbs an we all wanna see ya fly Quote
neilwillis Posted April 15, 2006 Posted April 15, 2006 I'm saying nothing about Zetecs here, Scott would probably blow a gasket. I hope you get it sorted soon mate. Go crack open an Easter egg, and go back to it tomorrow, it'll all seem much less of a problem when you've slept on it. Quote
perksy Posted April 16, 2006 Posted April 16, 2006 it'll all seem much less of a problem when you've slept on it. Agree, sometimes it pays to have a break from it and then you'll come back and look at it in a different way. Too much work gone into it now Scott, It'll fly when it's all working Quote
stu.graham Posted April 16, 2006 Posted April 16, 2006 Scott, did you get my message about the short oil filter It will be all worth it in the end Scott Quote
