Dave Eastwood (Gadgetman) - Club Secretary 7,612 Posted August 16, 2020 Share Posted August 16, 2020 The ratios on a good spec type 9 from BGH, SPC etc are massively better than the MT75, Mazda box etc. To be honest, I seriously miss my old Quaife Pro Type 9 gear ratios, and gear shift quality when I drive the Honda six speed gear box on the S2000 Westfield. The thing is, the proper Type 9 upgrade boxes are effectively re-engineered boxes that happen to share the same casework* shafts, and a few other core components, but in other ways, are completely re-engineered boxes, with modified lubrication, new gear sets, etc. *and of course, if you go for an aluminium main case, then even the type 9’s old cast iron job, is defunct. I like many, many, many Westfield owners before and after me, still maintain, the single best/biggest upgrade to Westfield performance and drivability, was swapping to a Type 9 with proper ratios, matched to a lightweight car like a Westfield. Quote Link to post Share on other sites
Chris King 4,817 Posted August 16, 2020 Share Posted August 16, 2020 21 minutes ago, MR.C said: Chris , in what way would you say it was better? Apart from of course being able to take more Power safely. Can you change from first to second swiftly if giving it the beans so to speak? Yes you can. On my BGH box gear changes are much better that my previous “straight out of an 80’s Sierra” type 9. Basically, it can easily take the power, it will change better and it allows me to accelerate in first rather than change gear after a mere microsecond.. It’s quite simply one of the best upgrades I have made (and if you ask those that know, I have made quite a few!) The other upgrade I really like is 13” wheels. Tough call as to which I’d put as the top upgrade, but the gearbox is certainly up there and something I would never regret paying the extra for. 1 Quote Link to post Share on other sites
Steve (sdh2903) 3,450 Posted August 16, 2020 Share Posted August 16, 2020 15 minutes ago, Dave Eastwood (Gadgetman) - Club Secretary said: The ratios on a good spec type 9 from BGH, SPC etc are massively better than the MT75, Mazda box etc. Not as different as you might think dave. A long 1st type 9 Is around a 2.98 ratio in 1st. A mazda mx5 5 speed box has a 3.13. The rest are closer still. Granted I know the extra long 1sts are available. With fresh correct oil Id say the mx5 5 speed box is one of the best changing manual boxes around. And at around 10% of the price of a good type 9, abundance of availability and capability to take much more power than even an uprated type 9 makes them a fantastic choice for a westfield. Also options now exist to mate to a zetec and bolt directly to a duratec/2.0 ecoboost. 1 Quote Link to post Share on other sites
Chris King 4,817 Posted August 16, 2020 Share Posted August 16, 2020 7 minutes ago, Steve (sdh2903) said: long 1st type 9 Is around a 2.98 ratio in 1st. That’s the “basic” long first. Other ratios are available that make it a better proposition 😁 mine is longer (ooer Missus) Quote Link to post Share on other sites
Steve (sdh2903) 3,450 Posted August 16, 2020 Share Posted August 16, 2020 Show off 1 Quote Link to post Share on other sites
Dave Eastwood (Gadgetman) - Club Secretary 7,612 Posted August 16, 2020 Share Posted August 16, 2020 1 hour ago, Steve (sdh2903) said: long 1st type 9 Is around a 2.98 ratio in 1st. that’s nothing like mine, I’m afraid. it was a 2.39, it’s a massive difference on the road, when paired with the right diff etc. the SPC ones I mentioned are an even bigger difference, 2.482 or 2.29 Granted, the BGH are a little bit closer, 2.66 and 2.75 are popular, but I believe there is a 2.98 in the range? Which would be closer to what you’re talking about. Quote Link to post Share on other sites
Ian Kinder (Bagpuss) - Joint Peak District AO 5,035 Posted August 17, 2020 Share Posted August 17, 2020 21 hours ago, JohnCh said: They take the rear portion of a sacrificial Type-9 case, attach the shift rod sections with a coupler and roll pins, then attach the two cases with a thick U-shaped aluminium bracket (~6mm thick). Here are photos taken before installing mine back in 2007. -John That's clever and looks much better than a heavily cranked lever! Quote Link to post Share on other sites
Paul Hurdsfield 748 Posted August 17, 2020 Share Posted August 17, 2020 32 minutes ago, Ian Kinder (Bagpuss) - Joint Peak District AO said: That's clever and looks much better than a heavily cranked lever! Thats what i've got Quote Link to post Share on other sites
