Madness kit Throttle Body upgrade
Hi
Been away again, but managed to phone Mark at WF to talk through details of the upgrade.
As already discussed this is effectively the same set up as the speed sport. Price does represent a real saving over buying a one-off from elsewhere or even from WF.
Mark explained that a new engine loom will be provided.  I don't relish trying to re-install through the transmission tunnel into engine bay as heater will be in the way unless scuttle is removed, but Mark suggested that a simple route would be through the scuttle like the heater pipes.
Trying to pull cash together this week for deposit cheque as I don;'t want to miss out on this opportunity.
:D Rick
  • Replies 205
  • KerryS
    65
  • MAT1800
    24
  • Blatman
    20
  • jak
    19
No you don't!!!
It won't work until there's enough folks to stump up the ££ :p
Kerry S
Looks like I got something right then...
So what is different about the engine loom?
Different connectors I think?
Don't know how to size pictures, but somebody will?
...and how do I make my pictures smaller?
Got a top tip off adhawkins,
if you are running windows XP go to the microsoft site and search for XPpowertoys. There is an image resizer, download it and you will be able to resize the picture using a right click.
TED
:D  :D
Flappa makes 5, I think... ???
Spoke to Chad at WF to put down my deposit, not sure exactly how many there are confirmed to date.
Just a couple more maybe.
I'll check with Mark at the end of this week, but I think he should have 5 deposits now
me
Mat1800
jak
gavin
Flappa
If I've missed anyone out...???
Kerry S
Sorry, John. Thought you'd already sent it.
Kerry S
Cheque now written and will be in the post first thing tomorrow.
I don't understand the comment about the engine loom & the scuttle/transmission tunnel. My engine loom is wholly in the engine bay.
Thanks, Bill. Now We Are Six - a book title I think? (Arthur Ransome - Swallows and Amazons series)
There are two wiring looms on the car, the main one (lights, switches etc etc) and a second one that links the sensors, ECU and engine.
From what Mark said, I thought he was adding to that but maybe it's a new one altogether.
Now, I ran my engine loom from the ECU over the passenger footwell, through a 50mm hole in the transmission tunnel cover in a similar manner to the main loom. This then ran over the gearbox/bell housing into the engine bay.
From Flappa's photo, he ran his throughthe scuttle. If the loom has to be changed, he'll have less of a struggle than I will to re-fit a new loom.
Does that help?
Kerry S
Or you could have placed your ECU on the front of the scuttle under a plastic cover, making it very easy to change the ignition loom.
:D:D:p:p:D:cool::cool:
True - I had assumed Bill had a "standard" Madness kit but of course I have seen some cars with ECU in the engine bay.
Kerry S
Dumb question # 34, will this very interesting conversion still meet the dreaded emissions level at future MOT's ??
Yup...
