Car boot stuff,
geofff
Hi,
Right I'll be bringing the following along to "Meet the Neighbours":
3 banjo casings - A pint each. ONE for DickieB TWO REMAINING
4 speed RS2000 gearbox - £25 - I bought it as spare to rebuild with TranX kit - bought a second hand SCCR in the end so no longer needed. Gone to John!
3 Girling master cyclinders with integral reservoirs  - fitted but never used - went Wilwood - £15 each - They cost £35 from WF! Price reduced
Brand new parts from my crated engine (Escort 1.8 130PS) which are not needed:
Clutch & pressure plate £15
Exhaust manifold - standard Ford £5
Inlet manifold and various injection thingy's - standard Ford £20
Plastic thermostat housing £10 - I've gone water rail
Old set of instruments from an SE which I bought of Ebay before spending money on Racetech ones £10. SOLD
There will probably be other parts posted later - I'm going out to the workshop and clearing up shelves etc... in readiness for build number two.......
All available at The Highwayman on July 2nd!
Ta
Geoff
Extra kit:
WF exhaust shield and jubilee clips - £15 SOLD
Brand new 200mm jockey wheel - £4 Price reduced
Black GRP race seat / anti submarine fin / shoulder head support with ali fittings 40cm wide at widest / lowest point for those narrow bodied fitting questions- £50 SOLD
Steering column upper - total refurb needed - as in plastic bushes etc...£5
Steering column lower - Allegro adjusted type - needs sanding and painting - £10 - been painted white previously! SOLD
Some sort of gearbox / engine mount - no idea but I'll bring it along - came in my kit.  ???
CXR wheel centres (sparkly silver things) £1 each
Brand new off crated engine 1.8 flywheel £25 - Save the £50 exchange on that lightened one without dismantling your engine first! Price reduced
Set of front wishbones - older type with 4 bolt bottom ball joint £35 SOLD
Single front upper wishbone £8 SOLD
Extra Extra kit:
Bright ORANGE Ford plastic crate for Zetec engine - basically ideal for neat engine storage if you don't have engine stand - pint! :)   DickieB first refusal
Link to comment
Hi Geoff,
I could use the Zetec Thermostat housing but I'm not able to go to the MTN weekend  :(
However I do know of a few from our area (Bristol & Bath) that are going so I guess we could organise something, let me know if this would be OK and if it is, how much you would like for it.
Chris
Link to comment
If by banjo casing you mean a piece of metal that holds the diff and half shafts on a live axle, then yes please to 1 of them!
Dickie
Link to comment
Hi,
Chris_G - £15 - how much do they cost normally?  This may be OTT or I may be kicking myself later ??? Not a problem re pick up - just get someone to come along and mention your name. BTW It also has the thermostatic fan switch in it. NNew & unused.
DickieB - yes you can even choose which one you want!  :)  I also have some back plates / various bits etc.. if I remember to bring them along - you never know something might prove useful
Potster - old, no where near as good looking as my racetech instruments and no manual telling me how to fit them to my wiring loom :D pictures sometime this week.
Ta
Geoff
Link to comment
bttt  :D
And I will get my :arse: into gear and put some pictures up ASAP.
The one below shows the engine crate, Ford exhaust manifold, Ford inlet manifold and injection bits & pieces, plastic thermostat housing.
Link to comment
Geoff, by adjusted do you mean it has been lenghtened? If the joints are good I will take that off your hands. I will also pick up the thermostate housing for Chris.
jeff
Link to comment
Hi Jeff,
This is one where the builder has been able to find an Allegro column and handed it over to WF for lengthening / new Escort UJ  for connection to rack. It's been painted !white! and has surface rust - needs sanding and repainting, in black  :)  obviously. I was going to get this done in the paint shop at work but I found another column already done  :)
Chasmon has sent me PM regarding this and exhaust cover - pictures which I will be posting tonight. If he decides not to go for it you have second shout, okay?
Ta
Geoff
Link to comment
Pictures:
Potster the clocks are really off - unless you're an electronic genius and you can do something with sticky back plastic ala Blue Peter - you can have them for free! Buy me a drink if you're feeling really kind  :D
Ta
Geoff
P.S.
Thanks to Andy for the hosting service. I promise to take all the pictures off on Sunday.
P.P.S.
The clutch is brand new - I didn't have the dehumidifier on for the first couple of weeks and it surface rusted. What clutch do the guys bolting zetec to MT75 use?
Link to comment
Geoff,
Any idea if the GRP seat will fit in a Narrow bodied car?
Also do you know what make it is in case I wanted a matching one?
Chris
PS Thanks (again) to Jeff for the thermostat housing collection...TOP MAN! :D
Link to comment
Hi Chris,
I beleive it will fit a narrow bodied car. Major Stare was looking at buying it before his better half bought him a Play's kool one! Obviously a beautiful girl!
I bought it from a chap on the Isle of Wight (Ebay) who said it was an early WF design copied from a Cateringvan Super 7 seat. I have the old fashioned Super 7 seats in my car with anti submarine fins and no back / shoulder support (I'm from karts and prefer the seat this way).
If you'd like me to measure the base tonight I can do.
Also the seat comes with ali fixing bracets - not pictured.
Ta
Geoff
Link to comment
Geoff
Do you have the crate that the engine came in? I've been looking for something like that for my spare XF engine....
Dickie
Link to comment
Extra Extra kit:
Yep  :D
Ta
Geoff
Link to comment
Hi Dickie,
When you pop over (any idea on time yet?) you're quite willing to take it and try it out. Drop it back if it doesn't work.
If it doesn't fit I'm sure a builder planning on using a scrapyard zetec will be along at some point.
Ta
Geoff
Link to comment
