brian d Posted February 6, 2005 Posted February 6, 2005 Having just had to pay for a replacement tax disc, following the theft of the original disc from the car, has anyone got a way of fixing the replacement disc so the same thing doesn't happen again? Or am I the only one who has had this problem? Quote
Enterpryse Posted February 6, 2005 Posted February 6, 2005 Have a peek at some of the motorcycle ones, lots to choose from... eg http://www.mandp.co.uk/productInfo.aspx?catRef=525651 http://www.mandp.co.uk/productInfo.aspx?catRef=525653 mounted on the bracket normally used for the the hood (assumes you aren't using one) but there are still loads to choose. Good luck Quote
Matt Seabrook Posted February 6, 2005 Posted February 6, 2005 I have one of these and been ok so far. On saying that now I bet it gets nicked next time I am out Quote
Darrell O'Neill Posted February 6, 2005 Posted February 6, 2005 I have one of these and been ok so far. On saying that now I bet it gets nicked next time I am out Quote
KerryS Posted February 6, 2005 Posted February 6, 2005 My daughter had her tax disc stollen from moped when she was at uni so I fitted one of the bolt together type as identified on this thread. I then used a coach bolt with the domed head outside, removed one of the panels and put the nut on the inside to make it as difficukt as possible for the next toe-rag. Done same to my scoot too. Absolute wotsit each 12 months to pull it all apart Also, they seem to leak water in. Some have an O-ring seal which helps but I usually smear Vaseline over the joint each year too. Kerry S Quote
Pete Collins Posted February 6, 2005 Posted February 6, 2005 You can get "tamperproof" tax disc holders from most car accessory shops. It doesn't stop them getting stolen but prevents the thief from changing any of the details on them - so they can't change reg number, for example. They are clearly marked "Tamperproof" and so discourage theft. I've used one for several years without problems. You do need a new one each time you change the disc but they're only ~£1.50 a time. Quote
Tony B Posted February 6, 2005 Posted February 6, 2005 Ive got one of the carbon bike jobbies, risk is that the moron steeling it may make more damage when ripping the whole thing off the panel its bolted to so he can dismantle it later... Quote
Cavvy Posted February 11, 2005 Posted February 11, 2005 The easy way of doing it is to just photocopy it on a descent photocopier, then just put the photocopy in the car, works for me haven't had any problems as yet because you can't tell any difference to a real one if you get a good copy. Quote
S8ight Posted February 11, 2005 Posted February 11, 2005 until you get a fine for failing to display your road tax Quote
Cavvy Posted February 11, 2005 Posted February 11, 2005 For the minimul amounts that police stop kit cars, the amount of miles the majority of us do and the wonders of modern photocopiers I think its worth the tiny risk Quote
pistonbroke Posted February 11, 2005 Posted February 11, 2005 lookin at me new disk it seems to have a sort of hollergram thingy to stop the fakers from fakin em Quote
Rob Navin Posted February 11, 2005 Posted February 11, 2005 When I take mine on the road I keep the tax disk in my wallet. That way if I'm stopped I can produce it. I don't do many road miles though Quote
pistonbroke Posted February 11, 2005 Posted February 11, 2005 Hey! Westfieldman who'se nicked yer tax disk ? Quote
