itguy Posted August 20, 2004 Share Posted August 20, 2004 Another vote here for the X-flow, nice and simple (although if you get throttle bodies/3d ignition etc it can get a bit more complex ) Quote Link to comment Share on other sites More sharing options...
Doug D. Posted August 20, 2004 Share Posted August 20, 2004 there is something about a xflow engine REBUILD IT I DID IT WAS WAY CHEAPER THAN A CONVERSION AND IT FLYS Quote Link to comment Share on other sites More sharing options...
woodman Posted August 21, 2004 Share Posted August 21, 2004 A x/flow is a perfectly good engine to contest classA of the speed series and took the first 4 places in class a last year , and will almost certainly win class a this year. However unless you throw quite a lot of money at it you will struggle to be competetive in class c if you move up the following year.So it may be more cost effectiveto fit a more powerful engine now. regards stu hill Quote Link to comment Share on other sites More sharing options...
Blatman Posted August 21, 2004 Share Posted August 21, 2004 Very true. In all the banter, we've forgotten the sensible suggestions for replacing the X-flow, if that's what you want to do. The Toyota 4AGE and Vauxhall 1.6 16valve have both been put to good use in the Speed Series, and are excellent choices for fitting in where a x-flow once sat. Quote Link to comment Share on other sites More sharing options...
