brianm Posted July 25, 2004 Share Posted July 25, 2004 VX SBD 75 DEG, THERMOSTAT, how to bleed What is the purpose off this??? B. Quote Link to comment Share on other sites More sharing options...
oioi Posted July 25, 2004 Share Posted July 25, 2004 the bleed or the thermostat? the thermostat is for a cooler engines which release bigger bangs its quite a common mod to the Vx engine - i guess they benefit from running cooler more than other enginess Quote Link to comment Share on other sites More sharing options...
brianm Posted July 26, 2004 Share Posted July 26, 2004 the bleed or the thermostat? Yeah, the thermostat, I know the standard is 92 and lower stat of 88 is available but 75 just seemed way low? Quote Link to comment Share on other sites More sharing options...
oioi Posted July 27, 2004 Share Posted July 27, 2004 ive been running the 75 deg thermostat for 3+years with no bother - except the engine seizure but that had b******* all to do temp with temp and all to do with oil - or lack there of Quote Link to comment Share on other sites More sharing options...
Arm Posted July 27, 2004 Share Posted July 27, 2004 Is the lower temp rating stat only available from SBD or was it used on any other Vauxhall applications ? Ash Quote Link to comment Share on other sites More sharing options...
oioi Posted July 27, 2004 Share Posted July 27, 2004 I only know mine came from SBD. Havent heard of anybody else supplying them? Doesnt mean that they are not an OEM part tho. Quote Link to comment Share on other sites More sharing options...
Arm Posted August 4, 2004 Share Posted August 4, 2004 Did you find a way of getting the excess air (and water) out of the system ? Quote Link to comment Share on other sites More sharing options...
windy Posted August 4, 2004 Share Posted August 4, 2004 The stat is available off the shelf from Vauxhall dealers. Can't remember the part number but i'll try to post it on here if I can find the receipt. Not sure why people are suggesting you bleed the stat? When it opens as the engine gets up to temperature air is bled out when the coolant flows through it, so it's not necessary to do it. You just need to let the engine cool back down again & top up with coolant afterwards. Hope this helps. Quote Link to comment Share on other sites More sharing options...
scott beeland Posted August 4, 2004 Author Share Posted August 4, 2004 Did you find a way of getting the excess air (and water) out of the system ? I think the answer to that one is definitely yes Quote Link to comment Share on other sites More sharing options...
scott beeland Posted August 4, 2004 Author Share Posted August 4, 2004 Hope this helps. S'pose it would've done Shin skin anyone?? Quote Link to comment Share on other sites More sharing options...
