adhawkins Posted June 3, 2004 Posted June 3, 2004 Hi all, This months Cheltenham, Gloucester and North Wiltshire meet will be on 24th June, at the usual venue (the Highwayman, off the A417 North of Cirencester). Hopefully the weather will be good again, and we'll get another good selection of cars turning up. Some pictures from the last meeting are here. Look forward to seeing you there. Andy Quote
Crash Override Posted June 3, 2004 Posted June 3, 2004 I shall be there again with the Westfield, sunshines booked for the I hope. Andy will you be making it to Combe next Saturday for the action day, there's a convoy in place from Tonys house. Quote
adhawkins Posted June 3, 2004 Author Posted June 3, 2004 Andy will you be making it to Combe next Saturday for the action day, there's a convoy in place from Tonys house. Anything's possible (was talking to Tony about this earlier). Will depend on a number of things (the weather and permission from the wife amongst them ). We'll see. Still planning on going on track? Andy Quote
Crash Override Posted June 3, 2004 Posted June 3, 2004 Very tempted, I'll see what nutters are there first I think. Quote
adhawkins Posted June 3, 2004 Author Posted June 3, 2004 Very tempted, I'll see what nutters are there first I think. Very wise. However, apparently the earlier sessions are the safer ones... Andy Quote
Crash Override Posted June 3, 2004 Posted June 3, 2004 Tony says the session booked for 11.00, what do you think? Quote
adhawkins Posted June 3, 2004 Author Posted June 3, 2004 Well, if he's booked a Westfield only session, then I say go for it. Would be tempted myself if I thought I'd pass the noise test... Andy Quote
Crash Override Posted June 3, 2004 Posted June 3, 2004 Unfortunatley it's not a westfield only session, so we'll just have to see. I'm not totally sure that mine will pass noise level, on the SVA it came in at 98Db at 7000rpm. Quote
adhawkins Posted June 4, 2004 Author Posted June 4, 2004 Unfortunatley it's not a westfield only session, so we'll just have to see. I'm not totally sure that mine will pass noise level, on the SVA it came in at 98Db at 7000rpm. You should easily pass then. I think the limit is 100dBAat 4500 RPM at Combe... Quote
adhawkins Posted June 4, 2004 Author Posted June 4, 2004 Andy do we mention the 3rd of July ? I'll check with Tony first...wouldn't want to 'steal his thunder' so to speak. Andy Quote
adhawkins Posted June 4, 2004 Author Posted June 4, 2004 And do not forget at 1/2 a metre Good point, what distance is it measured at SVA? Andy Quote
Crash Override Posted June 4, 2004 Posted June 4, 2004 And do not forget at 1/2 a metre Good point, what distance is it measured at SVA? Fairly close to the end of the exhaust, about 30cm I would guess maybe closer. Quote
adhawkins Posted June 4, 2004 Author Posted June 4, 2004 Fairly close to the end of the exhaust, about 30cm I would guess maybe closer. In that case, I would have thought you'll easily pass. Combe measure further away at lower revs...should be a doddle. Andy Quote
