darthurs Posted April 19, 2004 Share Posted April 19, 2004 I have a wire attached to the side of my dissy. What is it for? Where does the other end attach to? Sorry for all of the questions. Cheers Dan Quote Link to comment Share on other sites More sharing options...
Stevo Posted April 19, 2004 Share Posted April 19, 2004 Is there only one wire? Mine has three one for each side of the coil and an earth. Stevo Quote Link to comment Share on other sites More sharing options...
darthurs Posted April 19, 2004 Author Share Posted April 19, 2004 No. There is just one. So I assume that this is the earth (where does this go?) and someone correct me if I am wrong but your dissy might have a ballast resistor fitted so that could be what the other two wires are for? Or I could be taking through my Cheers Dan Quote Link to comment Share on other sites More sharing options...
Stevo Posted April 19, 2004 Share Posted April 19, 2004 The earth for the horn is pretty close so I used that. Quote Link to comment Share on other sites More sharing options...
darthurs Posted April 19, 2004 Author Share Posted April 19, 2004 Good idea. Can anyone confirm if I am right about the ballast resistor and the extra wires. I need to buy a ignition coil and I don't know which one to get. Cheers Dan Quote Link to comment Share on other sites More sharing options...
Man On The Clapham Omnibus Posted April 19, 2004 Share Posted April 19, 2004 I assume you're not talking about the wire that goes to the coil from the contact breakers (if any)? Quote Link to comment Share on other sites More sharing options...
darthurs Posted April 19, 2004 Author Share Posted April 19, 2004 Could be?? All I know is there is one wire that is coming off the dissy. I don't know what it does I only assumed it was an earth wire. It is a Bosh Dissy without a vacuum advance, if this is any help. Cheers Dan Quote Link to comment Share on other sites More sharing options...
Blatman Posted April 19, 2004 Share Posted April 19, 2004 One wire, or a sheath containing 2 wires? Have a good look......... Quote Link to comment Share on other sites More sharing options...
elpks Posted April 19, 2004 Share Posted April 19, 2004 Dan, It connects to the -ve side of the coil. The +ve side of the coil then connects via a ballast resistor to switched 12V. You can arrange for a relay to short out the ballast resistor during starting for a fatter spark if you like. If you have contact breaker points you will need a ballast resistor and a coil designed to be used with the points, otherwise you'll burn the points and will be forever adjusting them. Phil Quote Link to comment Share on other sites More sharing options...
darthurs Posted April 19, 2004 Author Share Posted April 19, 2004 That has confused me even more. I will put a pic of the dissy and wire in a sec once I figure out how to do it. Cheers Dan Quote Link to comment Share on other sites More sharing options...
darthurs Posted April 19, 2004 Author Share Posted April 19, 2004 Here we go. Wire is on the left... So where does this go? Dan Quote Link to comment Share on other sites More sharing options...
Man On The Clapham Omnibus Posted April 19, 2004 Share Posted April 19, 2004 Don't know if this helps but the wire to the coil from the contacts is usually black and white. I'm not sure at all what I'm looking at in your picture. Unless it's that rubber connector with a green wire next to it. Quote Link to comment Share on other sites More sharing options...
elpks Posted April 19, 2004 Share Posted April 19, 2004 Yep, there is a white + black stripe wire with female spade connector on that comes out of the loom right next to the dizzy. It connects to this. Phil Quote Link to comment Share on other sites More sharing options...
pookie Posted April 19, 2004 Share Posted April 19, 2004 The green wire on the dizzy is the condenser wire the black wire with the shroud goes to the negative side of the coil either directly or indirectly (through the loom). HTH Pookie Quote Link to comment Share on other sites More sharing options...
darthurs Posted April 20, 2004 Author Share Posted April 20, 2004 This is making sense now as I didn't know what the black/white wire off the loom was for. So where does this ballast resistor come into the equation then? Thanks for the help. Dan Quote Link to comment Share on other sites More sharing options...
