mTT97 Posted December 8, 2025 Author Posted December 8, 2025 31l fitted with custom vent loop. Thanks to @Rednop1for the tank Hope this tank won't leak from the vent nipple. For sale the old 21l tank, in case someone might be interested. 2 Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted December 8, 2025 Posted December 8, 2025 Good work @mTT97 I found the self adhesive pads didn't stick too well to the tank. I hope yours do! Quote
mTT97 Posted December 8, 2025 Author Posted December 8, 2025 1 minute ago, Ian Kinder (Bagpuss) - Joint Peak District AO said: Good work @mTT97 I found the self adhesive pads didn't stick too well to the tank. I hope yours do! It's already gone Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted December 8, 2025 Posted December 8, 2025 14 minutes ago, mTT97 said: It's already gone I put cable ties under the aluminium tank straps. Then fasten the hose to the cable ties with other cables ties. 1 Quote
mTT97 Posted December 27, 2025 Author Posted December 27, 2025 No more play in the steering column! New POM bushes. 25.00mm external diameter 20.12mm internal diameter 15/17mm height 1 Quote
mTT97 Posted December 28, 2025 Author Posted December 28, 2025 Additional dash printed, painted and fitted. 3 Quote
eggontoast Posted December 29, 2025 Posted December 29, 2025 21 hours ago, mTT97 said: Additional dash printed, painted and fitted. How is this secured, @mTT97? Screws to tunnel top? Hung off tube at bottom of dash? Quote
mTT97 Posted December 29, 2025 Author Posted December 29, 2025 6 hours ago, eggontoast said: How is this secured, @mTT97? Screws to tunnel top? Hung off tube at bottom of dash? See the previous page of my diary, i can share the 3D design if you need it 1 Quote
eggontoast Posted December 29, 2025 Posted December 29, 2025 Apologies, I'd completely missed that. Thank you for offering to share. 1 Quote
mTT97 Posted 3 hours ago Author Posted 3 hours ago I'm still waiting for the definitive screw to be the delivered this week, but this is how the diy front arb will looks like. If anyone is looking for a front arb to fit fw/widebody chassis with rally design wide track suspension set-up, I can share the updated design for free on request. In the meantime, the protech schocks have been completely serviced, and the damper screw has been properly calibrated (some of my shocks were not damping at all even with the screw "closed"). Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted 3 hours ago Posted 3 hours ago Good work Matteo. You'll notice a vast difference in cornering with working shocks! 1 Quote
mTT97 Posted 2 hours ago Author Posted 2 hours ago thanks for your advice Ian, who can forget this moment when the inside tyre was about to lift Secondly, I'm planning to fit 250lb rear and 375lb front springs since I mostly travel with a passenger. (now I'running 200/300) 30 minutes ago, Ian Kinder (Bagpuss) - Joint Peak District AO said: Good work Matteo. You'll notice a vast difference in cornering with working shocks! 1 Quote
