On 22/06/2024 at 20:16, DeanMegaS2000 said:
Car had the slim plastic and alloy radiator on when I got it. Fan was running all the time. So new Coolex one on now IMG-20240622-WA0007.jpg.36a6828768e416e6660422378e5bc653.jpg
I have a Coolex heavy duty rad. Never had any issues with it and the do look great 👌
The 🥕 is on a diet! About a 5kg saving 🤣
  • Like 5
So what have you done there?
Nice alloy bell housing and an easy swap.
Swapped the cast iron one for a alloy bell housing, but had to cut the starter motor casing off as it clashes with the chassis.
Mountain biked in proper mountains for 1st time.... Austria @ 2000mIMG-20240630-WA0010.jpg.728b8f09eebb4ebb5d70584429ad7898.jpg
  • Like 5
The original foot plate weighs a ton so you will be glad you made this, I like it! I hope you have some blue and orange paint 😉
  • Like 4
Thanks Julie, I’ll see what I can do on the paint job!
  • Haha 1
22 hours ago, Stuart Davis AO - Devon Cornwall & Somerset said:
Thanks to Sean for delivering the Devon and Somerset Area flag to me recently, good to finally have it available for events.
Good work, just in time for Powderham.
  • Like 3
Thanks to Sean for delivering the Devon and Somerset Area flag to me recently, good to finally have it available for events. It only had a spike with it and a rather large base which you fill with water, so I thought I would make something more compact from bits and bobs I had around the garage, but mainly some aluminium tube from a broken camping chair, some threaded rod and a couple of blocks of wood. After a couple of false starts, this one works well, just needs a sand down and a coat or two of paint.
Great idea
Got the DA out, never compounded gel coat before, but it's coming up very well. :cool:
  • Like 4
If anyone's interested that Meguiars worked a treat, got rid of the minor swirls and not too aggressive. Helps its only half a car.
  • Like 4
Looks great , I need to do mine , did you just use a finishing pad on DA ?
No I just used a Scholl concepts purple pad. Removed all the swirls no problem and finished off with a turtle wax spray wax, I'm really happy with the results.
It's not perfect and tbh I never chase perfection when detailing, too dangerous I just look to make a good improvement.
A mate had the paint on his new GR86 ruined by a detailer chasing perfection, had to get painted.
