Finished spray painting an MNR in my amateur improvised  paint chamber . This time side panels painted with motip Black wheelspray matt.
Now just needs some stickers from trackdays ;)
  • Like 3
Made some covers for the rear roll bar today.
  • Like 5
Whilst trying to change the handle on the pull start of my mower….. I let go of the string.
Don’t try this at home kids!🤣
That is all 🤬🤬🤬🤬🤬
Now sorted but it took a while 🤪🤪
  • Haha 6
  • Sad 1
Tried to cheat and drill it out from underneath. Failed, so dash and scuttle/screen off in the end
  • Haha 4
Had a great day at Palmersport today..in the wet... was well run and great fun.
  • Like 7
They really do put on a great day don't they. Any trophies?
Yes.. Quickest in Caterham pursuit and Karting and finished second overall... driving the JP LM on slicks in the rain was interesting.. they changed to wets for the next session...
Yes was really well run... with plenty of spins and trips on the grass..in fact I enjoyed it more in the wet than the last time I went in the dry...
Excellent, nicely done. The JP LMs were probably my favourite of the day. Hopefully do another one day.
We went out for a drive on Sunday but turned back because a cracking/creaking noise from the car was getting worse. Stopped for a check over but couldn't see anything amiss so drove back home. Testing things out I did some driving along a pavement with drop-kerbs every so often. As the front nearside wheel went up and down there was a terrible loud crack/creak. Investigation shows it's one of the top wishbone bushes - presumably nylon - and as the inner sleeve rotates in the nylon (or the nylon rotating in the arm, eeek) it cracks loudly.
Squirting lube all over it has done nothing so i will have to strip the bushes out. Sadly with the way the bolts are fed from outside-in that means removing the nose cone and a water pipe. Hopefully get it sorted before malvern.
Interestingly, I backed the spaxs off all the way to allow the suspension as free movement as possible but it didn't seem to make any difference, I unbolted the lower damper eye bolt so i could raise/lower that corner assembly but couldn't budge it at all there was so much stiction in the rotating assembly of the bushes. I think it all needs pulling apart for a good checkover.
  • Like 3
  • Sad 1
IMG_0507.thumb.jpeg.7f94b815f15e9f37d167169fcd82dfc7.jpegBirthday present from my son.
Do you have a link to this please? Did you actually get ro drive that thing!!? Looks amazing. I can't imagine how much fun that must be in one of those 😳
www.palmersport.com
Have a look all info on line.. brochure plus videos with all the technical info about the cars...
Yes definitely get to drive them..and it's all in a great environment but one where you are encouraged to drive as fast as you can!
4 hours ago, Mole said:
www.palmersport.com
Sounds epic! I'll take a good look ta
Heading home from Dartford on Friday, my exhaust started sounding horrendous in the last 30 mins and I thought a bolt had come loose. Actually it had sheared off, no doubt stressed by my continuing to drive on our recent Exmoor trip after my exhaust bobbin had broken. Well worth it as I really enjoyed that day, but a pain to get out. I tried an extractor set I already had, but the drill didn’t touch the bolt, just skated around, so I bought some 8% cobalt drills and the 2.5mm went straight through, no problem! After that, the extractor did its job though would have been easier if I had got the hole more central! All set for Malvern now, ideally I need some new gaskets to arrive but could manage with old if pushed.
  • Sad 1
Sometimes the fluted type extractors work better on smaller sizes as they don't tend to spread to broken piece and make it tighter.
