Been to see Wheatus.
I'm still a teenage dirtbag.
  • Like 3
14 hours ago, Paul Hurdsfield - Joint Manchester AO said:
Here’s a view from inside, I can even wash the caravan up to the roof without ladders, and those that know me know that’s quite a feat 😂IMG_1741.thumb.jpeg.f9104b5e994fd1a8414e1cd5e13a5a8e.jpeg
I take it this sides really clean and the other side just up to the window sill 🤣
  • Haha 4
Rode the Ruthin MTB Marathon with my 12yo Daughter yesterday.
Really good day out apart from the MASSIVE climb at the start!
  • Like 8
Love this. I was wondering what to do with my spare metal bonnet badge and how to get rid of my yellow Momo steering wheel centre.
This is the perfect solution!
On 22/07/2023 at 08:10, Ewan said:
Chanced across a Westfield bonnet badge I bought a while back but decided not to fit. Then noticed it was the perfect size to replace the Momo badge in my steering wheel. Now looks way better.
Nope the dwarf wall goes all round, this is quite an early photo, the shrubs are higher than the caravan now.:pDSCF0099.thumb.JPG.18f3ecab2fc1b9c49c209dcab6d5cad8.JPG
Took my daughter to 417 Bike Park in Gloucester for her first Downhill race.
2nd in her age group 👍👍
  • Like 7
I have finally found use for 2 out of about two dozens os used wiper blades i kept in corner of garage for years.. last week wanted to throw it away, good I did not :)
IMG_20230925_142909616.thumb.jpg.1141dacf0c1a721478e02da07095097e.jpgIMG_20230925_142806709.thumb.jpg.d75eee3d5ecc8be742af5047852ba4f5.jpgIMG_20230925_142843580.thumb.jpg.db9a742cf763ca8f72bf9c939a4be7ef.jpg
Now, what to do with rest...
  • Like 4
I put up some new wall art in my home office! IMG_7961.thumb.jpeg.82db1b68f7a7ad73aba151e09ceeb44a.jpeg
  • Like 8
  • 1 month later...
I experimented with Chat GPT to create some Arduino code to control my button switch illumination level (Horn button, etc.).
Here's what I asked it:
"I want you to act as an arduino board. you are controlling the lights on 6 different buttons on the dashboard.  When the head lights are on you turn on all 6 button lights 50%. when the head lights are on and a button is pushed you turn that button light 100% and leave the remaining 5 button lights 50%, when the head lights are off and a button is pushed you turn that button light 100% and leave the remaining 5 buttons off.  What arduino code do I need?"
Here's what it gave me back:
const int headlightPin = 8; // Pin for controlling headlights (example pin number)
const int buttonPins[] = {2, 3, 4, 5, 6, 7}; // Pins for buttons (example pin numbers)
const int buttonLightPins[] = {9, 10, 11, 12, 13, 14}; // Pins for button lights (example PWM pin numbers)
void setup() {
  pinMode(headlightPin, INPUT);
  for (int i = 0; i < 6; i++) {
    pinMode(buttonPins[i], INPUT);
    pinMode(buttonLightPins[i], OUTPUT);
void loop() {
  int headlightState = digitalRead(headlightPin);
    int buttonState = digitalRead(buttonPins[i]);
    if (headlightState == HIGH) { // Headlights are on
      if (buttonState == HIGH) {  // Button is pushed
        analogWrite(buttonLightPins[i], 255); // Set button light intensity to 100%
        delay(100); // Debounce delay to prevent rapid toggling
        for (int j = 0; j < 6; j++) {
          if (j != i) {
            analogWrite(buttonLightPins[j], 128); // Set other button lights to 50%
      } else {                    // Button is not pushed
        analogWrite(buttonLightPins[i], 128); // Set button light intensity to 50%
    } else {                      // Headlights are off
          if (j != i) {
            analogWrite(buttonLightPins[j], 0); // Turn off other button lights
        analogWrite(buttonLightPins[i], 0);   // Turn off button light
In this code, headlightPin represents the digital pin for controlling the headlights, buttonPins array contains the digital pins to which the buttons are connected, and buttonLightPins array contains the PWM pins used to control the intensity of the button lights. The code continuously checks the state of the headlights and each button. Depending on the conditions specified in your requirements, it adjusts the intensity of the button lights accordingly.
I have no idea if the code is correct, but I was amazed that it gave me what it did from my description!
It's better at coding than simple thing such as 'how many times a day does the big hand overlap the little hand on a clock" 😉
The way to test the code it to put it in an Arduino and report back!
I'm not convinced the way the delays have been done to debounce the inputs (definately needed), will work correctly as the whole program stops whilst this is being done. However it's impressive that it knew to add the debounce function.
I've debounced mine by using counters external to the test condition and keep the code ticking round. Happy to share if you drop me your e-mail address via PM.
void setup() {
void loop() {
          if (j != i) {
          if (j != i) {
That's scary
58 minutes ago, Flying Carrot Steve said:
That's scary
Very powerful stuff indeed.
Trying to complete masonry around the weather.
  • Like 4
  • 1 month later...
After years of bodging, sawing things on wobbly garden tables or balanced between chairs, I finally built myself a decent workbench today. It’s made from two 18mm ply sheets, which I glued and screwed together before successfully dropping it edge on onto my toe whilst lifting it into place 🤬🤬🤣. Mrs Stu has a bad back so was unable to assist. It’s very solid, took my not inconsiderable post Christmas weight without a murmur of complaint!
Need to play around with where stuff goes, but I’ve got a pillar drill, power saw, grinding wheel and vice to play with. Plenty of work to do on the house where these will all come in handy.
  • Like 8
