CraigHew Posted December 18, 2020 Posted December 18, 2020 Has anyone come across anything similar in the UK? Was thinking about carrying a small emergency jack in the Westfield but at $220 plus shipping this one's a touch expensive. Edit: @CosKevcan you make me one? Edit: @Westfield Parts Dept would make a great accessory if you could mass produce? Quote
Andrew O Byrne White - Ireland AO Posted December 18, 2020 Posted December 18, 2020 I carry a standard Halfords scissor jack in mine. Held in place with one of these trimmed with a hot knife and riveted to the ally panel. Cheap and handy solution for an emergency! 2 Quote
CosKev Posted December 19, 2020 Posted December 19, 2020 21 hours ago, CraigHew said: Edit: @CosKevcan you make me one I wish! That's a job for an engineering shop soz,not a train driver in his garage with a angry grinder and a welder! I would bet a one off to be designed and made would be a lot more expensive than that one from USA. Why do you want a jack in the car anyway,unless you are planning on carrying a spare wheel I can't see any use for one? 2 Quote
CraigHew Posted December 19, 2020 Author Posted December 19, 2020 I havent carried a jack for the past 7 years, only a "slime" kit and its compressor. However when the inevitable puncture eventually happens i think i stand a better chance of plugging the hole ( ive bought a couple of decent kits) if i can rotate the wheel to an optimal position to work on. The elevated wheel will also re-inflate better without the put-put compressor trying to overcome the weight of the car too. Ive ordered a decent scissor jack with a ratchet handle. It just struck me that the jack i posted pictures of was the ultimate low entry jack.... 1 Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted December 19, 2020 Posted December 19, 2020 45 minutes ago, CraigHew said: I havent carried a jack for the past 7 years, only a "slime" kit and its compressor. However when the inevitable puncture eventually happens i think i stand a better chance of plugging the hole ( ive bought a couple of decent kits) if i can rotate the wheel to an optimal position to work on. Get @CosKevto push the car, forward or backwards to enable you to work on it without lifting! 45 minutes ago, CraigHew said: The elevated wheel will also re-inflate better without the put-put compressor trying to overcome the weight of the car too. It's a 650kg kit car not your Hillbilly pickup! 45 minutes ago, CraigHew said: I've ordered a decent scissor jack with a ratchet handle. I hope you never need it! 1 Quote
CosKev Posted December 19, 2020 Posted December 19, 2020 2 hours ago, CraigHew said: However when the inevitable puncture eventually happens i think i stand a better chance of plugging the hole ( ive bought a couple of decent kits) if i can rotate the wheel to an optimal position to work on Hmmm good luck with finding a puncture on a tyre that's still fitted in the rear arch of a Westfield! If the offending screw/nail etc has fallen out without pumping up the tyre and having a spray bottle handy to wet the tyre to identify the hole it will be a struggle! Just bang a aerosol in the wheel and get going Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted December 19, 2020 Posted December 19, 2020 1 hour ago, CosKev said: Hmmm good luck with finding a puncture on a tyre that's still fitted in the rear arch of a Westfield! If the offending screw/nail etc has fallen out without pumping up the tyre and having a spray bottle handy to wet the tyre to identify the hole it will be a struggle! Just bang a aerosol in the wheel and get going Nope it's fairly straightforward. Managed to plug and repair one in the rear tyre on mine in Aug. 1 Quote
CosKev Posted December 19, 2020 Posted December 19, 2020 56 minutes ago, Ian Kinder (Bagpuss) - Joint Peak District AO said: Nope it's fairly straightforward. Managed to plug and repair one in the rear tyre on mine in Aug. You're quite a lot younger,and much more agile than Ant and Decs Dad though......... Quote
Ian Kinder (Bagpuss) - Joint Peak District AO Posted December 19, 2020 Posted December 19, 2020 14 minutes ago, CosKev said: You're quite a lot younger,and much more agile than Ant and Decs Dad though......... Less than 500 mile old, R888R! 1 Quote
CraigHew Posted December 19, 2020 Author Posted December 19, 2020 1 hour ago, Ian Kinder (Bagpuss) - Joint Peak District AO said: Managed to plug and repair one in the rear @CosKev : disappointed you missed a trick with that one 3 Quote
ianali Posted December 19, 2020 Posted December 19, 2020 On 18/12/2020 at 16:38, AndrewOBW said: I carry a standard Halfords scissor jack in mine. Held in place with one of these trimmed with a hot knife and riveted to the ally panel. Cheap and handy solution for an emergency! Tools under the bonnet. There’s an idea. Quote
