Scruffy,
I'm a bit late to this discussion, but I have to say that the diff in the superb pic that you posted isn't an LSD, I'm 99.9% sure.
If it had an LSD you wouldn't be able to see the small internal bevel gears because they'd be buried within the LSD unit The LSD unit takes up the whole of that centre space and in fact becomes the carrier for the crownwheel.
I have a plate type English LSD unit in my SE but the appearance is much the same whether its a quaife ATB, plate type or viscous type:
So its seems you might not have an LSD if you can see the internal bevel gears ... ???
  • Replies 81
  • Blatman
    20
  • conibear
    11
  • scruffythefirst
    10
  • adhawkins
    8
Scruffy *does* have an LSD, trust me  ;)
The one in the picture may not be, but as I said before, I believe the non slip gubbins is nothing like the ATB or clutch packs of the "normal" LSD's.......
..sure, I can only comment on the one in the pic :)
Would like to see the inside of the LSD version tho, just out of interest, if any one has a pic handy ....
Me too. I've never actually had one apart, but I've heard from many sources that it does indeed look almost like an open diff.
Sadly, the XR4x4 Haynes manual doesn't have any pictures of a naked viscous LSD, otherwise I'd have put them up.
Er....
This picture appears to have come from this website.
Apparently the LSD parts are enclosed in the crownwheel assembly out of sight, but the picture is indeed a LSD version.
Must get around to fitting mine sometime soon.
Edit - the output shafts are difficult to turn independantly, as the diff is never totally free.
My IRS diff is brand new from Ford with a label marked lsd, I have a receipt from WF marked lsd.
If I gently drop the clutch from a standing start both rear wheels spin, enabling me to do a doughnut. This diff is stiff to rotate by hand and yes it has lsd oil in it and no its not noisy.
My friends cateringvan is stiff as well.
I dont know if this is relevant but my previous non lsd live axle diff was as loose as a goose. I could not do a doughnut from standing start. If this not relevant fire away :D  :D  :D
Thanks for the relies chaps but what I  really wanted to know was which ratios were commonly fitted to which cars. :arse:  :durr:  :durr:  :bangshead:
Will either most probably be a 3:62 or 3:92  ;)  :D  Try and find a 3:92 if poss  ;)  :D
3.62 to 2.8/2.9 XR4x4's. They are *ALL* LSD's.
3.9 to 2.0l 4x4's
3.36 to Sierra Estates
Not sure what Granadas had in them....
I said that yesterday.....
If you have a bog standard Ford LSD, or a Quaife ATB, you DO NOT need LSD oil. Ordinary EP90 is what to use. LSD oil is for use specifically with clutch type diffs. I don't think you'll do any damage, but if it was me, I'd change it......
Viscous and ATB's are silent in operation. Clutch type LSD are generally audible in use, and can be positively intrusive at walking pace......
It's stiff because it's new, and like Ian says, you'e also turning the viscous pack. You may also find the brakes normally drag a little.......
Relevant, because on a non LSD, once the unloaded wheel can't overcome the grip of the loaded, non spinning wheel, the donut stops. It's rare to get beyond 180 degrees from a standing start. With *any* LSD fitted donuts are a simple matter of throttle control, once the clutch is out.......
I can confirm the diff in my avtar (from mr B's sierra) looks exactly the same as Tims ( the picture i posted earlier).  You can most certainly see the bevel gears in both. I can't take a pic of it cos i'm 120 miles away and I have no digital camera - sorry.
Scruffy
This is why I stated an lsd is stiffer to rotate than non lsd
I'd agree but wish to add the input shaft is even stiffer than just one output shaft.
When lubricating the my lsd, Westfield, Ford and Hardy Transmissions only recommended lsd oil and NOT standard stuff, so I'll go with them on that one ;)  ;)
Sadly, they're wrong........if you like, I can scan and mail you either the Haynes XR4x4 manual info, or Ford's own Sierra Cosworth manual specs for oil in Ford viscous LSD's.
And your stiff diff theory is wrong too. The diff only starst to limit slip once a certain torque load has been reached. Up 'til that, the diff is effectively open. The minimum torque load for a viscous diff, according to the manual, is 22ft/lbs. I would imagine a new diff to be up around 30-40ft/lbs. The upper tolerance is 52ft/lbs. You cannot generate 22ft/lb's by spinning an unloaded road wheel with the car jacked up, unless you are doing the prescribed LSD efficiency test, which involves a torque wrench and some pretty swift movement.
Any chance of posting (or mailing me) the test? So i can tell if you've sold me a Sh*tter :0:D:D:D
Scruffy
IME, the an LSD sierra diff  is is tighter than a 'free' diff when holding the prop flange and turning an output shaft.
But a viscous Sierra diff does not need LSD oil in it, 'ordinary' spec stuff is recommended by Ford (even in Cozzys).
But I reckon the only damage done by putting LSD oil in a Sierra diff is to your wallet.   :p
You maybe right but my diff is stiff :p  :p  :p Stiffer than my previous non lsd. But I agree I expect it to loosen up but not that much.
It's a 4.09 which is not that common.
I've only installed the oil advised.
Why is it then these oil enhancing agents, can't think of their name at the mo, advise not to be used on lsd and new engines. Their products increases viscosity I believe, reducing friction of two metal surfaces. So thats the same principal here.
Ian
