I have finally been persuaded by my husband to change my crossflow and to get a 2.0 zetec.  I have an engine, engine mounts and no need to change the type 9 gearbox, that is it.  So looking for all the other bits......
  • Low level sump
  • Inlet manifolds for carbs
  • Flywheel
  • Starter motor
  • Alternator and fitting kit
  • ECU
What have you got ? :)
Don’t forget the exhaust manifold, clutch and possibly an idler pulley if it’s a blacktop 👍
  • Low level sump
  • Flywheel
  • Starter motor
  • ECU
Hi, I have a era low level sump which I just changed for the raceline unit. I also have a spare flywheel and possibly emerald k3 having just purchased a K6 but still unsure.
let me know if any of these are any good to you.
cheers
Craig
If @Soraya doesn't have the Ecu, I have a friend potentially looking for an emerald K3 ecu. What sort of money are you looking for @Wowblaauw
Hi guys,
Thanks for the offer but I have been told that I should look for an omex or dta ECU. Thanks for the offer Wowblauw xxx
