uprated Brakes - sourced
Hi all. im after a big brake kit or part of a kit for westfield/cortina hubs
ideally 260mm discs upwards (hispec/wilwood/AP etc) and ideally fit under 13's
thanks
@Rednop1 have you got some to offer?
Not sure if you have this sorted but we can get hold of the HiSpec kit with 260mm 1p discs or 275mm 2p discs (floating), Both are designed for use with a min wheel size of 13". The 260mm option uses single piece 260mm x 20mm discs and the Billet 4 Hispec Caliper and the 275mm uses 2 piece floating discs with a 26mm thickness and uses the RS114 Hispec Caliper.
The floating option is quite a bit more money though.
If you want to make sure of the fitment we can supply a template you can use to check clearances etc.
If you are interested let me know.
  • 4 weeks later...
I have a set of discs pads amd calipers for sale. New and unused. Hi-spec....... Let me know if interested.
@AndySheldon I’ve sent you a pm
@Hawkemotorsport apologies,  I’ve just seen your reply.
could you pm me prices for both kits please
No Problems :)
The HiSpec kit with 260mm Single piece discs with Billet 4 Calipers is £455 for the Anodised kit or £495 for the powdercoated option
The HiSpec kit with 275mm Floating two piece discs with RS114 Calipers is £960 is Anodised only (no Powdercoat option).
Neither kit includes pads or lines.
If you need any templates to double check clearances then please let me know.
Thanks @Hawkemotorsport the templates would be ideal as I have 2 different sets of wheels the need to fit under
5 hours ago, DMc said:
Thanks for that. is there a choice in piston diameter also? id be looking for close to 34mm
No piston option on the Billet 4 calipers but on the RS114 you have 34/41mm piston or the option for 38mm
Hispec recommend the 34/41mm
  • 1 month later...
Brakes have been sourced, thanks
I know you have put “please delete” on - but there’s some really useful info on here, so can we leave the thread up and just change the title to “now sourced” instead 👍
 People searching for info could find it.
Done 👍
Good work.
