Wipers Not Working - wiring diagrams needed.
All, I have a Westfield SEIW and the wipers don’t work.  I don’t have a wiring diagram but stripped dash today and checked the switch.  3 position switch and 4 connections on the back, in each of the positions I have 0ohms or there about a across the contacts when activated.  1-2, 2,4 and 4-5.
wipers didn’t work on middle setting, then the other night don’t work on either setting. Fuse is good and connections good.
Anyone got any wiring diagrams or ways to try each Park, Slow and fast would be great!  Save me messing around.
I’ll send some diagrams mate.
Check how the switch is earthed and check the earth is sound
If you search through Bugman's build thread for the word "wiper" he's got some diagrams covering both the switch side and the motor side. Takes a bit of thinking to get your head around what's happening with them though.
Toward the bottom of the page is a diagram that might help you as pointed out by AndrewOBW from my build
That's the one! And thanks @BugManfor creating it! That was a massive help getting mine sorted!
Yes, thanks indeed, @BugMan.
I modified it to show 2 standard 5 pin relays used with a high-side switching FreeWheel for @DE04* - might also help someone else (not as pretty as the original, though):
I've got the ground switched Freewheel diagrams at home too, although hand sketched rather than in colour, so if anyone needs them in future I can dig them back out.
Nice bit of work there Kit Car Electronics on a great update, I'm more than happy to send you the original which was done in Microsoft Visio if it would be of any help? :westy:
