Throttle Position Sensor
Anyone have a spare throttle position sensor?
Just now, Matt_S said:
Any have a spare throttle position sensor?
For what?
Throttle bodies :d
  • Haha 1
Yes, for Jenvey throttle bodies
I do, but it’s a few years old and tbh I would get a Hall effect one, fit and forget.
I’m on holiday till 8 August
Andy
@Greenstreak-Andy D Can you give some feedback on the Hall effect version?
I am about to change my TPS sensor but would much rather prefer the Hall effect kind! Just looked at the Jenveys site they have a model available TP8RH would this suit all Jenveys TBs?
Thanks!
Thanks!
Hi @acafrao,
i replaced the TPS when I had a fast road cam fitted about 18 months ago. The original contact type hadn’t failed but was 10 years old and I just wanted reliability.
Omex ecu, cams and sensors all supplied by NMS. All had 10% discount from Troy.
From memory there here are two types of Hall effect, just direction sensitive.
When Troy mapped mine, he detected a small amount of movement between new tps and shaft of TB. So just check the output from TPS returns to original. Troy fitted a small shim in my case.
TPS was circa £100
Have done two European road trips without issue.
Andy
Thanks!
This is a one for the right hand side - https://store.jenvey.co.uk/throttle-bodies-and-components/throttle-position-sensors/tps-pg-contactless-rh-tp8rh
This one is for the left hand side- https://store.jenvey.co.uk/throttle-bodies-and-components/throttle-position-sensors/tps-pg-contactless-lh-tp8lh
Both should fit all Jenvey's, you just need to know if you need left or right hand side.
If you buy through NMS and Troy, he usually gives 10% off
Andy
Who is NMS?
Northampton Motorsport, a club sponsor
Oh right, thanks. Il contact them then👍🏼
New TPS fitted! The problem continues.. I now believe the problems is with the Jenveys ITBs as I can see some play within the butterflies opening.
Will test a new unit and let you now!
