Andrew Posted May 29, 2019 Author Posted May 29, 2019 Just now, Chris King - Webmaster and Joint North East AO said: Yes - my reply was more of a statement on the fit The only mod I had to do was provide clearance for the heavy duty bearing on the front face. Careful measuring and a hole saw sorted it. Quote
Kingster Posted May 29, 2019 Posted May 29, 2019 Yes same fit as the V6 hd type 9 with the extra bearing housing - but with the short shaft. Quote
Andrew Posted May 29, 2019 Author Posted May 29, 2019 21 minutes ago, Chris King - Webmaster and Joint North East AO said: Yes same fit as the V6 hd type 9 with the extra bearing housing - but with the short shaft. The shaft was the other thing.. Caterham boxes come in two different spline sizes, .. I got the "wrong" one. Had to fit a Puma clutch plate. Otherwise it would have been a straight swap using the Pinto clutch. Quote
