Stephen W Posted February 28, 2019 Posted February 28, 2019 Cosworth Supercharger kit Eaton M62 supercharger Cast housing and inlet manifold Inbuilt charge cooler DBW throttle but a cable one will fit too 550cc injectors (brand new) Map sensor Intake temp sensor Idler pulley Auto tensioner Charge cooler kit with pump, radiator and header tank Cosworth fuel rail but the standard one is fine Assorted hoses 3.3” pulley for 250bhp 7psi 2.9” pulley for 300bhp 12psi Will fit 2.0 2.3 and 2.5. Lovely compact unit that should fit.....just in a 7. £2500 £2000 1
Thrustyjust Posted February 28, 2019 Posted February 28, 2019 Is this similar to what goes in the C*****hams ?
Stephen W Posted February 28, 2019 Author Posted February 28, 2019 11 minutes ago, Thrustyjust said: Is this similar to what goes in the C*****hams ? They use a Rotrex type charger I believe.
Stephen W Posted March 6, 2019 Author Posted March 6, 2019 Also this will work with the standard bottom end and head/cams. The 2.9" Pulley @ 12psi will test it a little but in a car as light as a 7, it should be fine. Plenty of people using them in MX-5 as this boost on stock bottom ends.
AndyD-Yellow Peril Posted March 6, 2019 Posted March 6, 2019 Did you have this fitted to your Westie @Stephen W?
Stephen W Posted March 7, 2019 Author Posted March 7, 2019 13 hours ago, Greenstreak-Andy D said: Did you have this fitted to your Westie @Stephen W? No I had it on an MX-5 I've just bought. Its getting sold as I'm building another mental 260bhp+ N/A Duratec for it.
Thrustyjust Posted March 7, 2019 Posted March 7, 2019 Does it need anything else to get it going in a Mazda ?, as daughters other half has considered getting his done. Although might be at the wrong time for him to buy............
Stephen W Posted March 8, 2019 Author Posted March 8, 2019 11 hours ago, Thrustyjust said: Does it need anything else to get it going in a Mazda ?, as daughters other half has considered getting his done. Although might be at the wrong time for him to buy............ Yes. For an MX-5 it'd need, a pulley set up, a different thermostat housing and the PS pump lifting 10mm. Then a tune via a ECUTEK dealer. Not ott work, but work none the less.
