marcusb Posted July 31, 2018 Posted July 31, 2018 My alternator bracket has sheared 2 of the 3 mounting points I need one of these fairly urgent for a road trip ! anybody got one spare ?
CherryTreeFW Posted August 29, 2022 Posted August 29, 2022 On 01/08/2018 at 11:33, marcusb said: got one now @marcusb - would you mind letting me know where you got it from, please - I have a similar problem and I’m finding one hard to track down. Cheers - D
marcusb Posted August 30, 2022 Author Posted August 30, 2022 9 hours ago, CherryTreeFW said: @marcusb - would you mind letting me know where you got it from, please - I have a similar problem and I’m finding one hard to track down. Cheers - D @CherryTreeFW I was able to purchase a new one from the Factory, obviously not a option now for you, you could get your current bracket welded/repaired I suppose?
CherryTreeFW Posted August 30, 2022 Posted August 30, 2022 1 hour ago, marcusb said: @CherryTreeFW I was able to purchase a new one from the Factory, obviously not a option now for you, you could get your current bracket welded/repaired I suppose? @marcusb - thanks for coming back to me so quickly. I’m resisting getting it repaired at the moment as the inherent weakness is in the design. I’m looking at a Retroford mounting kit which, subject to dimensions matching would be perfect. Not much else available so if that fails, I can fall back on a repair or probably a remake using the old one as a pattern. Thanks! D
marcusb Posted August 30, 2022 Author Posted August 30, 2022 My failure was weld rather than bracket design, the weld was shocking no V prep just looked like a surface tack weld!
Benrobson2999 - Joint Kent AO Posted June 28, 2024 Posted June 28, 2024 I have the same issue. It’s welded back up but I may give the bracket to a fabricator to try and improve with a similar version 1
Craigieboy Posted June 30, 2024 Posted June 30, 2024 An old post, but still appears to be relevant for Black top owners. I was investigating a squeak from the drive belt and found I couldn't tighten the belt fully. I'll try and get it welded locally, however has anyone come up with a better solution? Thankfully it happened at home and not on a run.
Benrobson2999 - Joint Kent AO Posted June 30, 2024 Posted June 30, 2024 Here’s mine from a couple of weeks ago. Welded up but also keen to hear of any better solutions
Steve.Williams Posted April 26, 2025 Posted April 26, 2025 Same thing here, discovered today, think I'll get it welded up, but clearly not really up to the job
Craigieboy Posted April 26, 2025 Posted April 26, 2025 2 hours ago, Steve.Williams said: Same thing here, discovered today, think I'll get it welded up, but clearly not really up to the job If you've not already seen it, here's my post detailing my second breakage. I've not had any issues with the second bracket, which l feel is down to the extra support added and crucially not overtightening the belt. 1
Steve.Williams Posted May 4, 2025 Posted May 4, 2025 I got mine welded up, it's back on the car at the moment. So will see how long it lasts, if it breaks again then some additional bracing will have to be added 1
Craigieboy Posted May 5, 2025 Posted May 5, 2025 8 hours ago, Steve.Williams said: I got mine welded up, it's back on the car at the moment. So will see how long it lasts, if it breaks again then some additional bracing will have to be added Excellent and hope it lasts. At least now you know it's a weak point and can keep an eye on it. I always check it during pre-run checks and especially before a long run, it's a good habit to get into. 1
