*SOLD*1997 Westfield SEiW 230BHP Zetec
GiZmO1269
*Car now Sold*
Hi all - Thanks for looking
1997 Westfield SEiW 230BHP black top Zetec
Owned for 10 years. Needs TLC after long time of not much use. Just got it back from an engine and fuel line flush and running as well as the day we got it.
Genuine Westfield Nose and wing ready to replace damaged (still boxed). Car could do with a respray if to be used on the road.
Looking for £5500 – open to offers.
Mobile: 07758944196
Chassis
Westfield, IRS, widebody, Fully powder coate by factory.
RAC spec roll over bar with detachable rear stays.
FIA foam padding for RAC roll bar.
CAT motorsport wide track front wishbones.
CAT motorsport Aluminium hubs.
Poly brushed at front.
Front anti-rollbar by Terry Nightingale
Adjustable front shocks with 2.5" springs
Adjustable rear shocks with 1.9" springs
Quick Rack with modified steering arms.
Bodywork
Plays-Kool Motorsport front carbon cycle wings
Plays-Kool GRP race seats in black
Black Boot box
Plays-Kool motorsport dash
Reverie seat cushions.
Wheels
4 x TSW Evo alloys,black
Fitted with Toyota R888 195/50VR15 tyres
Engine
Fors 2.0 16v Zetec worked on by Rick Wood Engineering, 227.8 bhp. 172ft.lb Torgue
Ric Wood CNC Type R head
Jenvey 45  Throttle Bodies
Ported Dunnell race inlet manifold
Dunnell shortend baffled race sump, with modified pickup
Dunnell alternator mount
Dunnell lightweight flywheel and heavy duty clutch plate/cover
Lucas Starter motor
Braided Earls hoses
Tony Law 4-2-1 down pipes and collector
Oil catch tank with pipercross breather
MSD competion ignition leads and coil pack
Ric Wood high performance cams
Transmission
Ford BGH made type 9,5 speed gearbox. Fitted April 2005
Ratios
1st 2.75
2nd 1.75
3rd 1.26
4th 1.0
5th 0.84
ford 3.92 diff with viscous LSD
Westfield supplied propshaft
Brakes
CAT Motorsport 4 pot alloy calipers at front
STD westfield at rear
Fluke Motorsport lightenend drilled discs
EBC Greenstuff pads all round
Floor mounted pedals and clutch footrest in transmission tunnel
Electrics
Std Westfield wiring loom
DTA 3d management
Push Button start
SPA design rev counter and speedometer
Spa design oil presure and water temp guage
Westfield Electronic fuel gauge
Usual switches for lights etc
Sabelt 3" shoulder and 2" lap with aircraft style release(Dec 2004)
Other
Alloy Radiator
New Front Grill
Westfield supplied fuel tank with dry breather
Facet redtop fuel pump
Facet King filter
Momo quick release steering whee, SPA boss
Westfield side screens with elbow room
Carbon fibre rear light clusters
Small black M & P headlights
Boot box cover
3 piece weather cover
Link to comment
Hi All
To answer a few questions.
  • The car has been off the road for about 6 years, it will need a few things doing to pass its MOT. For example, the indicators don't currently work. The indicators are operated from the quick release steering wheel. a replacement socket is required on the dash where the cable plugs in. The reverse light works but lens is broke, so that will require replacing. Small things like that.
  • The full windscreen was removed after taking off the road, so not sure how current setup with aeroscreen affects MOT.
  • There is also a spare bonnet and the windscreen that came off the car
  • We are in Gainsborough, Lincolnshire
I've had a lot of interest in very short amount of time.
If you are interested, I would encourage you to come and view the car before making an offer. That way there are no disappointments.
We will be taking final offers on Tuesday the 7th to give enough time for people to see adverts and view.
Phil
Link to comment
