scott beeland Posted December 1, 2003 Posted December 1, 2003 Xantia 1.9 TD. Only 90 hp but 145 lb/ft torque at 2250 rpm. Indirect injection model (can't afford hdi common rail ) Worth buying or no? Only got 2k budget see so limited options Quote
Bananaman Posted December 1, 2003 Posted December 1, 2003 Body type Hatchback Number of doors 5 Number of seats 5 Engine (cc/type) 1905/4 Fuel type Diesel Max power (bhp/rpm) 92/4000 Max torque (lbft/rpm) 148/2250 Towing weight (kg) 1200 Kerb weight (kg) 1210 Manufacturer's figures 0-60mph (sec) 12.5 Max speed (mph) 108 Dunno if this helps Scott Quote
scott beeland Posted December 1, 2003 Author Posted December 1, 2003 Not really. I've got that info aswell Andy; but I need to know whether that translates into a capable towcar?? Ta anyway Quote
DAVE O Posted December 2, 2003 Posted December 2, 2003 Scott, Our Avensis is rated at 1300kg tow weight. It tows fine on M/ways etc even still pulls in 5th up the hills. It's not the quickest tow car but it does the job. If I had the budget I'd have gone for something with a bigger engine etc..... I would imagine the Zantia will have a far better torque figure so for the money it will probably do the job ok! What about a test tow before you buy? Also has it got air susp?? Dave O. Quote
felters Posted December 2, 2003 Posted December 2, 2003 If you're just towing the Westy and it's a two wheel trailer then should be Ok. Tools, spares and stuff are all going to add up though. I've just sold my old tow car for £1,000. 1992 Daihatsu Fourtrak 2.8TD - not very pretty but a great tow car. There are others about... replaced it with a 110 Defender TD5. (Ally body, steel chassis... spot a trend?) Quote
Al Yupright Posted December 2, 2003 Posted December 2, 2003 I have a pug 306 2ltr HDI, with 90bhp and 155lbft and its 'ok' at towing my light Westfield (450kgs) and trailer (500kgs). Its ok at about 60, but if you want to tow at 70 or are going somewhere hilly then it is a pain in the A*** and becomes hard work. Would like to change it for a 130bhp/>200lbft diesel but cant afford it.... Quote
John Loudon - Sponsorship Liaison Posted December 2, 2003 Posted December 2, 2003 Scott, Speak to these people. Ask them about their diesel towing upgrades. There is some info on the site. I have one of their smart boxes fitted to my normally 82bhp Astra van. It behaves like a GTi now and the mpg has hardly been affected and has much more power and torque than standard. John BTW - when I only had 82bhp, towing was still OK but now its better than OK Quote
thos Posted December 2, 2003 Posted December 2, 2003 My main car, and tow car, is a Golf TDI 130bhp with 228lb/ft as standard. But with a chip its getting 176bhp and 316lb/ft of torque. The chip is switchable and I've been towing with the chip switched on, but I do worry about my clutch with 316lb/ft going through while dragging the Westfield. I think I'll be dropping her back to standard from now on. It's still pretty nippy when towing, it does like a bit of wheel spin in 2nd, but this is probably down to bad weight distribution with the trailor. Quote
Nick Algar - Competition Secretary Posted December 2, 2003 Posted December 2, 2003 Scott, I used to have one of these which I towed a twin axle trailer with, worked quite well, certainly not a bad tow car. Your Minno and "new lightweigh Westie" should be OK. I had my'n from new and about Knackered it after 100K miles. Things to watch for on them are suspension oil pump, dropping rear suspension, dodgy gearbox. Engines is very strong, rest of car OK. When towing car suffer the normal front wheel drive problem of all the weight is at the back and losses traction a bit, but on normal roads should be OK. Cheers Nick Quote
Rob Navin Posted December 2, 2003 Posted December 2, 2003 Scott. Rocket Ron is selling his Audi 80 for a very reasonable amount. I am getting the info to post a ad for him on here tonight at the Yorkshire meeting. If you want any info give me a ring on 07984 164184 and I will pas your number on to Ron if he hasn't already got it. Quote
scott beeland Posted December 2, 2003 Author Posted December 2, 2003 Ta people. Think I'll get a xantia then . Being offered loadsa them at the moment; so just gotta find best one 4 the money Then I'm gonna BURN the escort Mr Navin. Let me know Scott Quote
Blatman Posted December 2, 2003 Posted December 2, 2003 IMO, I'd hang on to see what sort of money Ron is asking for the Audi. It *has* to be a better quality motor than the Xantia...... Which reminds me....the Xantia we had as a fleet car ('bout 5 years ago) had *the* most uncomfortable seats of any car I've ever sat in. When I was looking to upgrade from the 4x4, it was only the thought of the crap seats that had me removing the Xantia from my short list..... Quote
peterg Posted December 2, 2003 Posted December 2, 2003 had a Xantia as a company car about 9-10 years ago and have to say that the seats did my back in VW Passat or Audi TDi's would be a better bet Quote
Nick Algar - Competition Secretary Posted December 2, 2003 Posted December 2, 2003 I found seats depended on the model, high spec ones were OK for me. Quote
Blatman Posted December 2, 2003 Posted December 2, 2003 I had a bad back before I had a Xantia. Being handed the keys meant I took Ibuprofen (or Diclofenac, Scott and yes, I know it's slow acting........) before I set off. 30 minutes later, I'd be cursing, regardless of the medication, and I'd be limping for days........ Surgery cured the back, but the Xantia still gave me gip........ Quote
