jimbobtcc206 Posted April 29, 2018 Posted April 29, 2018 As I crack on with the mini overhaul of the Boghouse Blue I will have a few parts to sell most of which are for a C20XE engine. I am open to offers if anyone interested in buying anything. Shallow wet sump (Caterham manufactured) with baffle plate - £100 plus postage SOLD Oil pump with SBD uprated internal gear (when removed this has slight damage to part of the casing although a previous owner I contacted from this forum told me about this damage and it happened over 4 years ago so clearly had no bearing on performance of the unit - £100 plus postage. Selling as I have moved to dry sump. HiSpec ultralight 4 pot calipers (unbranded) in Black anodised. Suit cortina upright with solid discs. Need servicing/overhaul I suspect as pad wear was not even although when I spoke to hispec about the issue they said it was common if pads were getting too hot. I decided I wanted new brakes though - £50 for the pair plus postage SOLD Turbosport dry sump front cover plate (new and unused) - £75 plus postage Turbosport dry sump crank pulley (new and unused) - £35 plus postage Will accept £100 plus postage for the Turbosport bits if someone wants to take both. VDO gauges: Tacho (0-10k) - £40 plus postage SOLD Oil pressure - £10 plus postage SOLD Water temp - £10 plus postage SOLD Fuel level - £10 plus postage SOLD I can’t get pictures at the minute so will either update when I can or you can pm me and I can sort by priority that way.
B.RAD Posted April 29, 2018 Posted April 29, 2018 Hi mate, do the gauges come with the senders? Can you ping me some photos on WhatsApp of the oil, water and fuel gauges please? Cheers dude.
jimbobtcc206 Posted April 29, 2018 Author Posted April 29, 2018 Hi mate, I can get sender for oil and water but they’re at my engine builders at the moment. Fuel I’m keeping and using with new gauge. I’ll grab pictures a bit later for you. Not sure how good the oil pressure sender is though as I was getting low oil pressure reading at times and the engine is spot on when stripped so id guess the sender may have been a little temperamental.
jimbobtcc206 Posted April 30, 2018 Author Posted April 30, 2018 PM replied. brakes provisionally sold to Dom subject to payment.
jimbobtcc206 Posted April 30, 2018 Author Posted April 30, 2018 Tacho provisionally sold to Howard subject to payment.
jimbobtcc206 Posted May 1, 2018 Author Posted May 1, 2018 Brakes now sold. @neptune yes the oil temp, water temp and fuel gauges are still available.
Neptune Posted May 2, 2018 Posted May 2, 2018 17 hours ago, jimbobtcc206 said: Brakes now sold. @neptune yes the oil temp, water temp and fuel gauges are still available. @jimbobtcc206 thanks . Please pm me final cost and preferred payment details Thank you
jimbobtcc206 Posted May 9, 2018 Author Posted May 9, 2018 Bump.....sump, oil pump and dry sump bits still for sale
